Skywalker's dual light bars
  • Adamoffroad
  • Visitor
  • Visitor
20 Jan 2016 22:34 #160754 by Adamoffroad
Replied by Adamoffroad on topic Skywalker's dual light bars
You can't beat a good lightbar or two :laugh:
21 Jan 2016 06:36 - 21 Jan 2016 06:45 #160757 by skywalker65
Yes I got the brackets off eBay . I did post a link about them earlier. Bought a wiring harness off there too complete with 40amp relay,switch and deutsch connectors. It's really not worth trying to make your own harness.. All the wiring is located inside the cab and I just ran the light feeds and the wires to the battery through the bonnet release cable hole with a suitable grommet..
Fabricated some short extension pieces from the eBay brackets using some flat bar ( B&Q) and then bolted the light bar to a longer section of the flat bar. This moves the light bar just far enough away so you can pop the bonnet up. Light bars are quite wide compared to some spots I guess..
Top bar is 180 watts and the lower one is 120watts so the wiring kit can cope no problem. Running standard alternator too.
If any one fancies doing something similar I can always post more pics
If in doubt ...... Flat out ??
Last edit: 21 Jan 2016 06:45 by skywalker65.
21 Jan 2016 06:46 #160758 by skywalker65
191680313056 is the eBay item number for the brackets guys
  • Daniel30
  • Visitor
  • Visitor
21 Jan 2016 07:06 #160759 by Daniel30
Replied by Daniel30 on topic Skywalker's dual light bars
Thanks for all the information and yeah that's the brackets I was thinking about Cheers
Did you have to weld the metal on to bring the brackets out?
21 Jan 2016 07:14 - 21 Jan 2016 07:16 #160761 by skywalker65
Didn't bother welding the the extensions to the brackets Daniel. I just drilled 2 M10 holes in them and bolted one end to the flea bay bracket hole that's already there and the other to to the bar that supports the bar. Got some plastic nut covers to go on today to finish it off..
I prefer this method cos it's a doddle to unbolt should I need to. Whilst the top bar doesn't interfere with the headlamp aim etc ,you only need a slightly overzealous MOT tester to say it does lol
And basically I'm a shit welder too :(
Last edit: 21 Jan 2016 07:16 by skywalker65.
  • Daniel30
  • Visitor
  • Visitor
21 Jan 2016 07:18 #160762 by Daniel30
Ha ha yeah was going to say I haven't got any welding gear :woohoo: :woohoo:
Thanks for the info great help cheers
