Well Here she is the jimny
  • atnas666
  • Visitor
  • Visitor
22 Jan 2016 20:40 - 22 Jan 2016 20:42 #160892 by atnas666
Replied by atnas666 on topic Re:Well Here she is the jimny
Yeah its a good cost for peace of mind.
I tend to so out often with just me and a passenger (lanes i know)
And want to explore more.
So its needed.
Some videos here if any one is interested.
quality of Oxfordshire ones are rubbish forgot to change quality before upload
Last edit: 22 Jan 2016 20:42 by atnas666.
  • atnas666
  • Visitor
  • Visitor
23 Jan 2016 13:52 - 23 Jan 2016 14:00 #160924 by atnas666
Replied by atnas666 on topic Well Here she is the jimny
Well here are the things i gotta fit over the coming weeks
Light bar
[IMG
Caster correction bushes
[IMG
2nd Battery tray
[IMG
T-Max split charge
[IMG
Winch tray with heavy duty recovery points (not looking forward to the fitting of this)
[IMG
T-Max 9000lb outback series winch with wireless remote
[IMG
[IMG
[IMG
[IMG
Last edit: 23 Jan 2016 14:00 by atnas666.
  • atnas666
  • Visitor
  • Visitor
26 Jan 2016 20:38 #161247 by atnas666
Gonna try and fit the correction bushed Thursday eve.
Any advice?
  • Daniel30
  • Visitor
  • Visitor
26 Jan 2016 22:10 - 26 Jan 2016 22:11 #161265 by Daniel30
Replied by Daniel30 on topic Well Here she is the jimny
Plenty of lube ;-) and don't rush it ( ooooooo la la)
Last edit: 26 Jan 2016 22:11 by Daniel30. Reason: Ad
  • atnas666
  • Visitor
  • Visitor
27 Jan 2016 19:47 #161322 by atnas666
Daniel30 wrote: Plenty of lube ;-) and don't rush it ( ooooooo la la)
Pre lubing has started on bolts in prep for 2moz night
  • Daniel30
  • Visitor
  • Visitor
27 Jan 2016 20:14 #161324 by Daniel30
Nice, plenty of pics please would like to see how this winch mount and winch fit ;) as it's on my list to do :woohoo:
  • atnas666
  • Visitor
  • Visitor
27 Jan 2016 20:36 #161327 by atnas666
Daniel30 wrote: Nice, plenty of pics please would like to see how this winch mount and winch fit ;) as it's on my list to do :woohoo:
Be a while till I get to that lol. To scared to do the cutting lol..
  • atnas666
  • Visitor
  • Visitor
28 Jan 2016 12:03 - 15 Feb 2016 15:25 #161368 by atnas666
Well today i did one of the jobs on the list.
[IMG
Second battery tray fitted was really easy
Caster correction bushes tonight. Nicked the local Citroen garage for the evening ;) Helps knowing the work shop manger!
Then tracking etc at local garage in the morning
Last edit: 15 Feb 2016 15:25 by atnas666.
  • atnas666
  • Visitor
  • Visitor
29 Jan 2016 00:59 - 29 Jan 2016 01:04 #161418 by atnas666
Well spent 5hrs tonight trying to fit the radius correction bushes.
First issue was needing to undo the shock absorber. Witch did not wanna come undone.
Then the actual undoing of the radius arm well this was easy as pie.
Now getting the old bushes out. This was how do I put it a ***t of a job.
And took 3.5hrs of the job lol. Even with a 20ton press they did not want budge . So after a lot of struggling and then giving up... I SET THEM ON FIRE! this got rid of the rubber.
Next was the air saw and chiesl to remove the metal sleave.
Then the easy bit fitting the poly bushes.
Now refitting the arm this was a pain to get the holes in the rite place. Ended up jacking the other side of car up to aling the them.
So at least one side is done!
And tomorrow I'm gonna burn the ***ts out from the get go!
Last edit: 29 Jan 2016 01:04 by atnas666.
29 Jan 2016 17:36 #161442 by kirkynut
Replied by kirkynut on topic Well Here she is the jimny
I drilled the rubber out of the bushes until I was left with just the metal ring around the outside of the bush and knocked this out with a small cold chisel after slicing it with a hacksaw first.
The following user(s) said Thank You: atnas666
  • atnas666
  • Visitor
  • Visitor
05 Feb 2016 16:34 #161901 by atnas666
Well got some where today
  • atnas666
  • Visitor
  • Visitor
06 Feb 2016 19:38 #162000 by atnas666
Winch fitted and wired with tmax split charge system :)
Time to create page: 0.162 seconds
