Vinnies 53 jim jam
I've run without them for years with no issues and have been through some real gooey crap!
- Vinnie
- Visitor
kirkynut wrote: I would just lose the shock boot mate. The theory is they protect the shaft from dirt and debris that may effect the seal but realistically they serve only to retain moisture which rusts the shaft which damages the seal.
Yer I did think about removing them.Prob will when I remove exhaust,pipe that goes into cat has fell out got temp fix at moment :laugh:
- Vinnie
- Visitor
kirkynut wrote: If you do remove it don't mess about with taking the shocks off. Just cut them off. If you then decide you wish you'd left them on for some reason, tell me and I'll post them to you from my stock of unused ones! They're no good to me!
Ok cheers kirkynut
- Vinnie
- Visitor
I wound them in on a threaded bar with blocks of wood with holes in as big washers that wouldn't damage the poly.
- Vinnie
- Visitor
kirkynut wrote: Good job! How did you get them in? Plenty of grease is always a good help I find.
I cheated they are the two piece bush :laugh:
- Vinnie
- Visitor
