green turtle
  • vdl
23 Sep 2014 18:03 #124880 by vdl
Replied by vdl on topic green turtle
gearbox bolted
engine starts and runs
alternator giving ~14.6V - nice
rear sidegears in front diff
  • vdl
23 Sep 2014 19:58 #124892 by vdl
if anyone wants to know about alternator - bosch "0 124 525 030"
really tight fit - almost touching engine mount
belt 4PK0884
  • lindsay
23 Sep 2014 21:25 #124909 by lindsay
Replied by lindsay on topic Re:green turtle
Hey looks like a nice build, what amp is alt? Does it bolt straight in?
Btw I am running rs shafts and cvs and there spot on, touch wood :)
  • vdl
23 Sep 2014 21:34 #124910 by vdl
Replied by vdl on topic Re:green turtle
140A
jimny mounts were a bit modified to fit it
i'll take photos tomorrow
  • vdl
24 Sep 2014 18:29 #124977 by vdl
radiator back in
front axle ( still empty ) in place with springs and shocks and arms attached
front diff assembled
alternator pics
upper mount needs offset
lower mount needs longer bolt
it goes through first mount ( offseted ~11mm to the radiator and trimmed so bolt don't mess with belt )
then through distancer
then uses original mount and thread - bolts through and goes into second alternator mount
if you use longer bolt then you can finish with nut to more secure alternator in place
  • vdl
12 Oct 2014 16:31 #126299 by vdl
front diff in
one side done - halfshaft, kingpin, etc
also trimmed hub nut to fit hubs without spacer
seems than boggers are still touching body at max - hammer or cutting/welding will help
rockwatt transfer box in place
waiting for rs to send right longer halfshaft
Time to create page: 0.289 seconds
