Rally-raid Jimny (G'Luck Racing)
  • TomDK
05 May 2014 23:38 #114294 by TomDK
Replied by TomDK on topic Rally-raid Jimny (G'Luck Racing)
Jimny_Aus wrote: anyone know what shocks these are?? they look like Bilstein 5156's......
You mean Bilstein 5165's right? :)
On the IFS Jimny?
  • Jimny_Aus
07 May 2014 00:16 #114349 by Jimny_Aus
Replied by Jimny_Aus on topic Rally-raid Jimny (G'Luck Racing)
i should have put my glasses on hahahaha :blush:
  • gluck3d
07 May 2014 18:18 #114395 by gluck3d
Replied by gluck3d on topic Rally-raid Jimny (G'Luck Racing)
Video from one of the stages (it was 3 stages total with more then 300km of race distance total)
The worst problem was sliding on wet mud after the rain... Couldn't drive faster then 40km/h sometimes
  • miktt100
08 May 2014 16:57 #114493 by miktt100
Replied by miktt100 on topic Rally-raid Jimny (G'Luck Racing)
Cool vid , I wouldn't drive my j that fast on the road ;)
It would be good to have something like that in the uk , be a bit shorter tho
  • gluck3d
12 May 2014 07:09 #114918 by gluck3d
I bet there is something. Search for Cross-Country Rally, this is how it is called in UK if I am not mistaken. There should be some entry-level competitions.
Also in our case there was a special class called 'raid' with minimal requirements to enter - just helmet, extinguishers and racing license. They had to drive not as fast as they could, but to finish at pre-defined time. Both pre- and past-time finishes receive penalties (earlier finish receives double penalties). A good way to try this sport without spending much ;) Not sure if this class exists in UK though
  • gluck3d
26 Jan 2015 11:38 - 26 Jan 2015 11:39 #136045 by gluck3d
After I have unfortunately ended the season in July due to my father passing away, I've decided to prepare Jimny for winning next year (already this year now) and have started searching for racing suspension, engine etc.
Engine choice was quite simple - have bought quite fresh M18A, cause the procedure of its installation is well-known.
Regarding suspension - we have decided to use King Shocks, which are one of the leading US manufacturers for off-road competitions. We have thought it would be a bit cheaper then Ohlins (but it is not actually :) ).
After reaching one of the dealers (FilthyMotorsports) with our ideas (we wanted to keep the suspension quite similar to stock, but replacing shocks to racing set with external reservoirs and internal bump stop and appropriate springs), I've provided many details to the dealer Ben and he has proposed to use coilovers instead. This way we are also able to use external bump stops for more reliability.
Therefore the decision was done:
2.5" coilovers both in front and rear, 10" extension front and 8" rear. Double-rate springs package front, single rate rear.
Something like that:
Unfortunately it all took long time to order due to many reasons like me not knowing how to do this :) (also Christmas holidays took its toll) and we have ordered them only mid-January and I hope we will get them here in Moscow by the end of February.
Meanwhile we have time to prepare for coilovers installation (have photos of front part only yet):
There will be a strut between top points of this mountings above the engine.
Battery was moved behind the seats. Brake lines will be replaced with racing ones.
Also we need to make aluminium wall behind the seats and place at least 100L gas tank in the back.
Will post more photos when I have some :)
I hope this year I'll be able to stand on podium some times :)
Last edit: 26 Jan 2015 11:39 by gluck3d.
