New blue jimny project
  • 2014Nathan
  • Visitor
  • Visitor
06 Mar 2014 18:46 #107478 by 2014Nathan
Replied by 2014Nathan on topic New blue jimny project
kirkynut wrote: Looking good and you don't hang around do you!
I fancy you'll need s lift for them tyres. Insa Turbo come up big.
Yes it catches now and then but driving about and light byways seems fine only bigger things they catch at the moment soon as I get paid again will look into the lift kit :)
  • 2014Nathan
  • Visitor
  • Visitor
06 Mar 2014 18:48 #107481 by 2014Nathan
Anyone fitted a 2" lift at home? Easy enough too do? :)
  • Adamoffroad
  • Visitor
  • Visitor
06 Mar 2014 19:20 #107487 by Adamoffroad
Replied by Adamoffroad on topic New blue jimny project
You can fit a lift at home best way is to rest the chassis on an axle stand and let that side your working on hang (after you have removed the wheel) then just disconnect the shock, then you can just push the axle down by hand enough to put the spring in then just use a jack to push the axle up enough to put the shock in :)
Just make sure on the front you disconnect the anti roll bar and the brake line from its holding clip and you wont have any problems. Hope this helps :)
  • Bigjim91
  • Visitor
  • Visitor
06 Mar 2014 19:34 #107489 by Bigjim91
Replied by Bigjim91 on topic New blue jimny project
Remove ya anti roll bar while ya at it, b the best thing u do, aslong as u got extended brake hoses
  • 2014Nathan
  • Visitor
  • Visitor
06 Mar 2014 20:07 #107497 by 2014Nathan
Adamoffroad wrote: You can fit a lift at home best way is to rest the chassis on an axle stand and let that side your working on hang (after you have removed the wheel) then just disconnect the shock, then you can just push the axle down by hand enough to put the spring in then just use a jack to push the axle up enough to put the shock in :)
ok thankyou! well hopefully not too long and i should get the kit
  • 2014Nathan
  • Visitor
  • Visitor
06 Mar 2014 20:08 #107498 by 2014Nathan
Bigjim91 wrote: Remove ya anti roll bar while ya at it, b the best thing u do, aslong as u got extended brake hoses
what advantages will it give removing the roll bar bud?
  • Bigjim91
  • Visitor
  • Visitor
06 Mar 2014 20:45 - 06 Mar 2014 20:46 #107507 by Bigjim91
We'll I recently removed mine and that it's a lot smoother on and off road, all so off-road more articulation, grip, coz the front axle can move like the rear
Last edit: 06 Mar 2014 20:46 by Bigjim91.
  • 2014Nathan
  • Visitor
  • Visitor
07 Mar 2014 06:58 #107542 by 2014Nathan
Ok might look into it :) Some thing else to add to the list to do haha
  • jonesyba420
  • Visitor
  • Visitor
07 Mar 2014 09:00 #107549 by jonesyba420
Replied by jonesyba420 on topic New blue jimny project
Remove the ARB you wont regret it especially offroad.
10 min job if the bolts come out lol.
Keep it in the shed tho as its abit of a grey area when it come to MOT time.
  • 2014Nathan
  • Visitor
  • Visitor
07 Mar 2014 10:20 #107551 by 2014Nathan
jonesyba420 wrote: Remove the ARB you wont regret it especially offroad.
Alright will look into getting some extended hoses ;)
  • 2014Nathan
  • Visitor
  • Visitor
09 Mar 2014 23:15 #107989 by 2014Nathan
Nice view from the woods looking over Bristol suspension bridge tonight
  • Red One
  • Visitor
  • Visitor
10 Mar 2014 18:50 #108050 by Red One
Replied by Red One on topic New blue jimny project
Looking Good! Which size special tracks did you go for?
Time to create page: 0.189 seconds
