My Jimny From Portugal
- TomDK
27 Mar 2014 22:40 #110372
by TomDK
Replied by TomDK on topic My Jimny From Prtugal
You don't need the springs compressing tool if you remove the lower bolt from each shock. Then it's easy to install the spring with the axle lowered. This of course requires that you jack up the Jimny and remove the tyres.
- Maze
27 Mar 2014 23:01 #110382
by Maze
I have the tool just in case of necessity!
But thank you for the tip...
Replied by Maze on topic My Jimny From Prtugal
TomDK wrote: You don't need the springs compressing tool if you remove the lower bolt from each shock. Then it's easy to install the spring with the axle lowered. This of course requires that you jack up the Jimny and remove the tyres.
- Maze
30 Mar 2014 00:25 - 30 Mar 2014 21:22 #110588
by Maze
Today was the day to roll up our sleeves and get to work ... put the new springs (+2") in front and the standard front springs in the rear!!!!
The placement of the Rear Panhard Relocation Bracket and the standard front springs in the rear...
The test to see if everything was okay
Conclusions...
The front and the rear is much softer, I should have to create or buy some Springs spacers with 10mm or 15mm tall to put on the back because I confirm the springs +2" (front) from jimnybits comes with about +3" and not 2" because the standard springs have about 340mm length and the srpings with +2" come with 415mm length +-
It's 5***** thumbsup
The parts left over... :evil: (...the rear standard springs and the home made springs spacers...)
Conclusions...
Last edit: 30 Mar 2014 21:22 by Maze.
- Maze
17 May 2014 08:23 - 17 May 2014 08:28 #115513
by Maze
I mount the rear rough country shock absorbers, but the shocks hitting in the springs, so I started to make some rear shocks repositioners/spacers that the center has shifted 5mm to the middle of the car to avoid the springs!!
when they are built and tuned I place photos and redo some measures of the sketch!!
Last edit: 17 May 2014 08:28 by Maze. Reason: Entering some text
- Maze
20 May 2014 21:39 #115905
by Maze
- Maze
22 Jun 2014 14:38 #118342
by Maze
Time to create page: 0.851 seconds
