A working progress
  • ritchie
  • Visitor
  • Visitor
18 Oct 2013 16:20 #86870 by ritchie
A working progress was created by ritchie
Hi,
I bought my jimny about a year ago and got it for a bargain due to the fact the 4WD didnt work. I took the gamble after reading so much helpful advise on the great site and after cleaning everything up, blowing through the vacuum pipes and replacing a chewed up wheel retaining nut (which the vacuum hubs seals on) CLONK the hubs engaged and the 4WD has worked perfectly ever since........Delighted.
I then replaced the drivers side kingpin bearing whihc was giving me a lot of problems and my jimny drove great.
  • Wiltec17
  • Visitor
  • Visitor
18 Oct 2013 17:26 #86886 by Wiltec17
Replied by Wiltec17 on topic A working progress
Sounds good! Don't you just love it when a plan comes together.
Have you modded it or just enjoying it in standard form?
  • markyp2000
  • Visitor
  • Visitor
18 Oct 2013 18:12 #86896 by markyp2000
Replied by markyp2000 on topic A working progress
Good job but theres no need to undo them 4 bolts behind the disc/hub
  • ritchie
  • Visitor
  • Visitor
18 Oct 2013 18:49 #86910 by ritchie
Replied by ritchie on topic A working progress
Markyp2000 ; I think I done a few things that wasnt needed that day. :laugh: was a slight learning curve.
Wiltec17 ; i Tried to add more pics and expalin what else I have done but my internet is being crap today. Try again though.
I then fitted some roof lights, bull bars and new tyres.
I wired up the two outside lights to the full beam and the inside ones to the stereo so i can use them independently when the ignition is on. also gave them a custom paint job with some spray paint and a handfull of leaves. ;) Thought it was a nice touch.
  • helijohn
  • Visitor
  • Visitor
18 Oct 2013 19:00 #86913 by helijohn
Replied by helijohn on topic A working progress
ritchie wrote:
It's looking great. B)
If they follow the guide they end up doing it...........I did!! :angry:
  • ritchie
  • Visitor
  • Visitor
18 Oct 2013 19:45 #86925 by ritchie
Thanks that was a while ago. since then its changed a bit. really struggling to get the pics up. its getting annoying.
I eventually decided on a lift and heres what i went for mostly because i use it a lot on the road swell.
Ive installed a ORA 2.5" mudskipper suspension kit. (rough country shocks)
castor correction bushes.
adjustable panhards.
modulars 15x7 et - 30. looks good with that offset.
Moved the position of the extra lights just for a nice change.
Cooper discoverer atr tyres - 205/75r15 which are good on the snow, which is one of the reasons i bought the jimmy.
All try again with more pics
Heres how it looks as of today.
  • ritchie
  • Visitor
  • Visitor
18 Oct 2013 20:54 #86941 by ritchie
The only problem Im having now is that my adjustable panhards are fully adjusted to the smallest lenght and the cab is still off centre to the axle. Any suggestions. also I think that the castor correction bushes are maybe just not rotating the axle far enough because the steering feels ok but still a bit light and wonders a bit. But like i said id finished this yday so not drove it much to really know for sure.
  • ritchie
  • Visitor
  • Visitor
18 Oct 2013 21:10 #86945 by ritchie
the lights i mentioned earlier.
  • ritchie
  • Visitor
  • Visitor
18 Oct 2013 21:19 #86946 by ritchie
Just need to tidy up and paint the undersides now.
  • helijohn
  • Visitor
  • Visitor
18 Oct 2013 21:24 #86947 by helijohn
ritchie wrote: Just need to tidy up and paint the undersides now.
Somehow the wheels suit that lift.
  • Wiltec17
  • Visitor
  • Visitor
18 Oct 2013 22:57 #86965 by Wiltec17
Looks fantastic. I like it.
I use photobucket to upload my pictures, just upload to photobucket then copy/paste the img link.
  • helijohn
  • Visitor
  • Visitor
18 Oct 2013 23:03 #86967 by helijohn
Wiltec17 wrote: Looks fantastic. I like it.
I don't because now and then over the years photobucket has messed up a good number of my links. Personally I would never recommend it for forum use when the forum has it's own file upload system. I have found the best way to put pics on here is to shrink images to say 50%, upload no more than three in each post and if you want more then edit the post later and add pics after.
Time to create page: 0.238 seconds
