swb´s Jimny
- swb
- Visitor
06 Jul 2013 10:18 - 06 Mar 2015 15:51 #76261
by swb
swb´s Jimny was created by swb
Hello everyone!!
My name is Raúl and I´m a new member from Spain
I´ve got a 1999 Jimny 1.3i japan made
Mods:
- Only front two seaters
- Black tinted rear windows
- All interior lights in leds
- CB radio and GPS
- TRAIL MASTER Steering Damper Kit
- Front MABILSA coils +4cm (+1.5")
- Rear TRAIL MASTER +5cm (+2")
- Rear TRAIL MASTER brake balance correction bracket
- Front and rear TRAIL MASTER +5cm (+2") shocks
- Transfer skid plate SC
- Radius arm mounting guards AFN
- Exhaust sport line VIMESA
- INSATURBO Super SP Track in stock size 205/70/15 (No Retread)
- Transfer iron mounts PROTRACK
- Transfer planetary PROTRACK with a final ratio 3.43:1 only on low range
Pics:
Mods:
- CB radio and GPS
Pics:
Last edit: 06 Mar 2015 15:51 by swb.
- Tadpole
- Visitor
06 Jul 2013 10:32 #76262
by Tadpole
Replied by Tadpole on topic swb´s Jimny
Welcome this fine forum it’s good to have you join us ................
- swb
- Visitor
06 Jul 2013 10:44 #76267
by swb
Replied by swb on topic swb´s Jimny
Thanks!!
Jimny section in spanish Suzuki forum is almost dead :laugh:
- rajsuzuki
- Visitor
06 Jul 2013 10:47 #76268
by rajsuzuki
Replied by rajsuzuki on topic swb´s Jimny
Welcome to bigjimny plenty of people here .
- swb
- Visitor
06 Jul 2013 10:51 #76270
by swb
and with a spanish section
- JuanGuillie
- Visitor
06 Jul 2013 14:33 #76282
by JuanGuillie
Replied by JuanGuillie on topic swb´s Jimny
Welcome here, Jimny is looking good!
What did you payed for these (Euro?).
- Transfer iron mounts Protrack (made in Greece)
- Transfer planetary Protrack with a final ratio 3.43:1 only on low range (made in Greece)
- swb
- Visitor
06 Jul 2013 14:39 #76283
by swb
Planetary and iron transfer mounts are sold together
1st and reverse gears on low range are really amazing
www.protrack.gr/proionta/suzuki/adm-menu...low-range-gears.html
- swb
- Visitor
06 Jul 2013 14:44 #76284
by swb
A little video on low 1st gear
- swb
- Visitor
06 Jul 2013 14:48 - 06 Jul 2013 14:52 #76285
by swb
If you need more info about this kit, tell me please!!
Your name is Juan, if you can speak spanish we could talk in the spanish section of the forum if you need complete data
Last edit: 06 Jul 2013 14:52 by swb.
- JuanGuillie
- Visitor
06 Jul 2013 15:39 #76286
by JuanGuillie
Si, mi nombre es Juan, pero yo tenia 7 anos cuando nos mudamos de Argentina a Belgica.
Mi Espagnol es muy malo, y tengo un monton de problemas para hablar o escribir.
Como se puede ver hago un monton de errores !
Por tanto, yo prefiero escribir en Inglés, ir mucho mas suavemente.
Mis disculpas!
My Spanisch is very, really very poor but... my Greek is even much worse :lol:
Is this low gear mounted in the original Jimny Dropbox, what are the changes to do?
Do you have an idea what you did pay for it (+ postage), is it long time ago, did you already got on steep slopes?
Can i have an English mail correspondance with them (Or French, German?).
If you have the time you can send me as much info as you can, that would be a great help, thanks.
Muchas gracias, buenas tardes !
Mis disculpas!
- swb
- Visitor
06 Jul 2013 16:21 - 06 Jul 2013 16:23 #76288
by swb
I commented you this because in a spanish forum specific to Jimny you have all necessary data but you need to be registered to view it. I´ll send you a PM with the forum link.
The kit is similar to Apio ones, it changes the original planetary for a new one. But in the ProTrack kit you need to reuse the original planetary satellites.
The reduction in low range is -60% and the high range stays the same. Perfect for use in road and highway
You should talk with ProTrack guys in English, I have dealt with them always in English
Reduction is spectacular, you need to speed up rather than slow down
Last edit: 06 Jul 2013 16:23 by swb.
- JuanGuillie
- Visitor
06 Jul 2013 17:24 - 06 Jul 2013 17:31 #76296
by JuanGuillie
Thanks Raul, i will check it on the Spanisch Jimny Forum but it will be not before monday.
I'm preparing my Jimny for tomorrow for a very beautifull roadbook in the French part of Belgium (region of Tournai).
Roadbook has also 4 private lands to cross, one of them is a 180 m deep quarry (cantera) where you got steep slopes (20 to 30 meter) down and up.
Some "trial" passages and rocks-section.
You can drive about a half day in it if you want to.
There is also a big sandpit, some passages into the "woods" (in Belgium these are not very big!).
I will try to make some pictures and films.
Last edit: 06 Jul 2013 17:31 by JuanGuillie.
