My ride.
26 Oct 2010 19:09 #5391 by mlines
Replied by mlines on topic Re: My ride.
The damper is will not cure wobble. It reduces the loosness and wandering that you get on long straight roads and makes it more positiv around corners
  • Adamski
26 Oct 2010 19:17 #5392 by Adamski
Replied by Adamski on topic Re: My ride.
mlines wrote: The damper is will not cure wobble. It reduces the loosness and wandering that you get on long straight roads and makes it more positiv around corners
Thanks Martin. I know it is almost impossible to cure completely, but what are the best things to do in order to reduce it?
I have very nobbly tyres, would less nobbly tyres help, or is it just the fact that I've put bigger tyres on (205/75) and less nobbly tyres would be exactly the same?
  • Reloaded
27 Oct 2010 08:56 #5400 by Reloaded
Replied by Reloaded on topic Re: My ride.
Just out of interest did fitting the modulars have any impact on your wobble either way Adamski?
  • Adamski
27 Oct 2010 13:49 #5403 by Adamski
Mick C wrote: Just out of interest did fitting the modulars have any impact on your wobble either way Adamski?
Fitting the wider offset modulars has made the car more stable at higher speeds however has also made the wobble a little harsher at 35mph than the standard 6" wheels. I really dont understand why the wobble occurs, can anyone shed any light?
  • Gromit
27 Oct 2010 15:47 - 27 Oct 2010 15:48 #5406 by Gromit
Replied by Gromit on topic Re: My ride.
Adamski wrote:
Gromit wrote: Adamski, wheel wobble is a bit bad which is why I"ve just ordered a steering damper. By the way tyre size is 235/75 not 265, sorry :whistle: :whistle:
Yeah ive got really bad wheel wobble between 30mph - 40mph so would be very interested to hear whether the damper makes a difference. Would you let me know and I might invest in one?
Did the 235/75 tyres require any arch cutting? and would they fit on 15x7 wheels?
I had to cut quite a bit off the front arches but not the rear ones.
They will fit on 15 x 7 wheels no problem.
I"ll let you know if the damper makes any difference or not.
This is the pile of bits after the butchery :)
Last edit: 27 Oct 2010 15:48 by Gromit.
  • Adamski
27 Oct 2010 19:11 #5421 by Adamski
Wow, that quite a bit of butchery. I was hoping to get away without cutting the arches, I may just stick with my 205/75's. Have you got a 3" lift as well?
Yeah that would be great if you let me know how you get on with the damper :).
Time to create page: 0.623 seconds
