Tim's 1.8L Jimny
  • tim80z
29 May 2013 21:58 - 29 May 2013 22:00 #72166 by tim80z
Replied by tim80z on topic Tim's 1.8L Jimny
Thanks for all the comments guys.
AndyMS43, Squibby's instructions can be found on Auszookers. Here is the link: www.auszookers.com/forum/viewtopic.php?f=17&t=30308
I'm not sure if you will need to register or not to see that post. If you don't have access just let me know and I will put up a PDF copy.
- Tim.
Last edit: 29 May 2013 22:00 by tim80z.
  • ATW1980
18 Mar 2014 20:10 #109018 by ATW1980
Replied by ATW1980 on topic Tim's 1.8L Jimny
Thanks for sharing..
The engine swap got my attention!...
  • rogerzilla
18 Mar 2014 21:19 #109042 by rogerzilla
Replied by rogerzilla on topic Tim's 1.8L Jimny
Amazing that it fits...but I suppose a 1.8 litre engine need only be a 1.3 litre engine with half a litre more empty space inside it :) All depends on the cylinder spacing, and some blocks are the same for many engines apart from the bore size.
  • Jimny_Aus
18 Mar 2014 23:36 #109058 by Jimny_Aus
Replied by Jimny_Aus on topic Tim's 1.8L Jimny
yea i thought with the M13-18 engines use same block......
  • rogerzilla
20 Mar 2014 19:57 #109298 by rogerzilla
Looking at the specs, the bore of the 1.8 isn't much bigger (the stroke is significantly longer) so it could well be the same casting.
Time to create page: 0.256 seconds
