Sheps awesome 2013 jimny
  • supergaz
  • Visitor
  • Visitor
08 Jun 2013 07:24 #73139 by supergaz
Replied by supergaz on topic Sheps awesome 2013 jimny
A bush press tool is not required with the kit. Its best to upgrade to superpro polybushes and they go in with a vice or mallet easily.
Service from ORA is always spot on, even when i've wanted custom parts made. I have earlier ora radius arms that are not plated and so offroading has stripped off the powdercoat for me, so they may get a lick of hammerite when I can be bothered.
Send Rob or Hen an e-mail and they always get back fast.
  • Shep
  • Visitor
  • Visitor
08 Jun 2013 10:54 #73153 by Shep
Replied by Shep on topic Sheps awesome 2013 jimny
Poly bushes don't last very long where I live as the dust is very abrasive and seeing as my car is brand new I reused the oem rubber ones.
Seriously, I have destroyed sj51 polly shackle bushes in 750km.
  • Shep
  • Visitor
  • Visitor
10 Jun 2013 07:48 #73361 by Shep
Done a bit more today, rear shocks have the same issue as the fronts.
The new rear arms have nothing to mount the abs string to so I think I will see if I can find my tap and die set and mount the string like the stock arms. Or I might just use cable ties. :whistle:
  • supergaz
  • Visitor
  • Visitor
10 Jun 2013 08:22 #73369 by supergaz
Shep wrote: Done a bit more today, rear shocks have the same issue as the fronts.
Its quite common to have to shave a bit off the bush, especially on the top of the rear shocks.
  • Shep
  • Visitor
  • Visitor
11 Jun 2013 00:04 #73462 by Shep
Is there a solution to this? I tried mounting them upside down however there is near zero dampening and mounted the right way they won't last 5 min of wheeling.
  • Smoggy
  • Visitor
  • Visitor
11 Jun 2013 06:14 - 11 Jun 2013 06:17 #73466 by Smoggy
Replied by Smoggy on topic Sheps awesome 2013 jimny
Shock repositioning brackets on the bottom. Again they are available from ORA or bigjimny I believe :)
I also welded on ORA bottom bracket skid protection plates ( I think they will just bolt on if you need to). They will help to protect the bottom of your rear shocks from impact damage. The thru bolts are easily damaged.
Last edit: 11 Jun 2013 06:17 by Smoggy.
Time to create page: 0.311 seconds
