JIMNY GR.
  • nasos
  • Visitor
  • Visitor
19 Feb 2013 09:10 - 19 Feb 2013 14:23 #63144 by nasos
JIMNY GR. was created by nasos
I have a 2003 mod. with lots modications......
1. Rancho shock absorbers with in-cab air controller
2. Mad springs with spacers
Total hight 6" or 15cm
3. front ARB locker
4. reinforced driveshafts and cv joints
5. rear ARB locker
6. longer brake lines
7. longer front radius arms
8. longer panhard rods and replaced higher
9. alluminum protection plates
10. 4.16 gears on samy transfer case
11. 30"-9.5-15 m/t yokohama tires
12. excell alluminum rims -20 offset
13. snorkel with kn air filter
14. T-MAX winch 9500 lbs with plasma rope 30metres
15. roof lights
16. H.I.D. head lights
17. tow bar
18. cb-vhf communications
19. alluminum wheel spacers 1.5"
20. throttle hand
21. Heavy duty transfer box mounts
22. steering dumper
maybe i forget some things but now i have plans for 2" body lift, roof rack like arb, and 31"tires!
Last edit: 19 Feb 2013 14:23 by nasos.
  • Sponnie
  • Visitor
  • Visitor
19 Feb 2013 09:20 - 19 Feb 2013 16:12 #63146 by Sponnie
Replied by Sponnie on topic Re: JIMNY GR.
Sounds great, got any pictures??
Sent from my GT-I9300 using Tapatalk 2
Last edit: 19 Feb 2013 16:12 by Sponnie.
  • nasos
  • Visitor
  • Visitor
19 Feb 2013 14:43 - 19 Feb 2013 16:52 #63167 by nasos
Replied by nasos on topic Re: JIMNY GR.
i can not upload pics! why???
Last edit: 19 Feb 2013 16:52 by nasos.
  • ilten
  • Visitor
  • Visitor
19 Feb 2013 16:13 #63180 by ilten
Replied by ilten on topic JIMNY GR.
Impressive Jimny! So, which shafts and CV's did you get? I've been running my front ARB locker for about 1.5 years now (30x9.5 and 31x10.5 BFG MT) and so far it's still holding together.... But I know that the day will come that I have to upgrade :dry:
ilten
  • nasos
  • Visitor
  • Visitor
19 Feb 2013 16:51 #63187 by nasos
Replied by nasos on topic JIMNY GR.
Reinforced front driveshafts and CV-joint for Jimny.
The driveshafts and CV-joint is made of chromonikeliouchous steels and heat treated for maximum strength.
The drive shafts are the same diameter on both ends (27,2 mm) and their placement, requires changing the front two planets, planets from the rear differential and have 26 teeth spline (26 spline).
To work correctly the factory hubs, is necessary to place new seals on the outer side of CV-joint and for this reason have a small machining inside the shafts (spindles).
I got them from dgtuning and its from a samurai and for this reason has a small machining inside the shafts!
  • panosd
  • Visitor
  • Visitor
19 Feb 2013 19:28 #63209 by panosd
Replied by panosd on topic JIMNY GR.
Καλησπερα κ καλως ηλθες.
How did you manage to fit them as they come from a samurai and samurai has diferent lenght in axleshafts?
To add pics 1. try through ex. imagashack or 2. attachments and add file below message box.
