renard38's jimny
- jonesyba420
26 Mar 2014 07:32 #110112
by jonesyba420
Whats this mod? Have you looked on his youtube channel he has loads of vids.
Replied by jonesyba420 on topic renard38's jimny
idiotmobil wrote: renard was it you that do the mod for the rear wheel bearings
- idiotmobil
26 Mar 2014 14:21 #110141
by idiotmobil
Replied by idiotmobil on topic renard38's jimny
it a od to change the way the bearings come out it changes abut of the back plate so you don't have to remove the brakes to remove the shaft it used to be done to sj413 and uses sj410 parts but I think it can be done to jimnys Im sure ive seen it somewhere on here thought it was renard but maybe not looked around on the net not found a good walk through manily the bits to buy and weather you use the jimny or sj bearings
- jonesyba420
26 Mar 2014 14:31 #110144
by jonesyba420
Ahhhhh I see. Need to do my bearings dreading it, any views on which bearings to go for Martin sells 2 kits one cheaper than the other? You can almost get 2 cheper kits for 1 expensive one so are the expensive ones almost twice as good?
- idiotmobil
26 Mar 2014 16:42 #110151
by idiotmobil
I get my own bearings front wheel bearing top quality from hendersons for £25 been using them for meny years
- Wiltec17
26 Mar 2014 18:30 - 26 Mar 2014 18:32 #110167
by Wiltec17
I did my rears the other day, they're not to bad, give me a bell if you get stuck when your doing them, but if you managed your kingpins then the rears will be fine, worst bit is removing the bearing race but I sure there is plenty of YouTube type vids that will help you out.
Replied by Wiltec17 on topic renard38's jimny
jonesyba420 wrote: Ahhhhh I see. Need to do my bearings dreading it, any views on which bearings to go for Martin sells 2 kits one cheaper than the other? You can almost get 2 cheper kits for 1 expensive one so are the expensive ones almost twice as good?
Last edit: 26 Mar 2014 18:32 by Wiltec17.
- idiotmobil
26 Mar 2014 18:38 #110170
by idiotmobil
www.trailtough.com/index.php?option=com_...6:techinfo&Itemid=60
bbs.zuwharrie.com/content?topic=123531.0
www.zukikrawlers.com/archive/index.php/t-37186.html
heres a few discusions on the mod im on about make doing rear wheel bearing a lot easyer
Time to create page: 0.502 seconds
