Show us your flex
  • gazwell
17 Nov 2011 22:55 #25990 by gazwell
Replied by gazwell on topic Re: jimny v6 trayback
thanks for that,the spec could be a bit long winded but theres not much i havent tweeked or changed!!
here goes : 2.5 v6 auto from a gv,pair of oddessy pc1500's,8274 with gp +3"drum+air freespool,gp h/d main shaft,+25%gears xp motor .rear winch warn xp with 8274 motor and modified rope retention system.
suspension arms kap h/d with polybushes all round, front arms extended 40mm,front axle is a modified sammy casing with chromoly 4340 shafts and cv's, modded arb to suit sammy shafts,diff is jimny ,rear axle is standard apart from arb and rear disc conversion.lowered rear top shock mounts and raised lower mounts (big jimny ones)custom rear winch tray with 2 swivel recovery points and ali tool box fitted behind under spare wheel.kap h/d panhard rod in rear,front one custom made (as i bent a h/d kap one).to rig up the jimny steering to the sammy axle i swapped the stub axle carriers left for right and right for left to put the part that the steering link bar rod ends go into behind the axle instead of in front, i then custom made a bracket to bolt on with the nearside caliper carrier to form an arm coming forward from the stub axle carrier to allow the jimny steering bar to connect to.inside is an arb h/d compresser and 1 gallon air tank to keep the 2 arb's and air freespool working nice. the rear tray holds 4 waffle boards,ground anchor(steel pin type for hard ground and hammer) ground anchor plough type,wheel brace,radiator/tranny cooler cooled by thermo controlled kenlowe fan. snorkel is ali linked to std airbox(sealed of course).
lights are 2 rear,2 rearside,2 front side,2 front spotsand 2 front fogs +headlights.bonnet is chequerplated in ali,as is the belly guard and front bash plate. i think thats everything!!! i cant take credit for cutting the cab down that was down to darren at kap who as you can see did a crackin job i got it back with just 2 chassis legs stickin out the back.all the rest of the work was done by myself.
  • zukenutter
17 Nov 2011 23:00 #25991 by zukenutter
Replied by zukenutter on topic Re: Show us your flex
  • X-Eng Simon
05 Mar 2012 07:51 - 05 Mar 2012 07:52 #34883 by X-Eng Simon
Replied by X-Eng Simon on topic Re: Show us your flex
I have something to post now!
Si
Last edit: 05 Mar 2012 07:52 by X-Eng Simon.
  • Sam_
10 Mar 2012 14:49 #35236 by Sam_
Replied by Sam_ on topic Re: Show us your flex
not too extreme but its a start...
  • ooky_123
10 Mar 2012 16:05 #35239 by ooky_123
Replied by ooky_123 on topic Re: Show us your flex
Hehe nice one. You get get balancing on 3 wheels if you try a little harder :)..
New tyres look good too :)
Now GET AND CLEAN HER !!!! :)
10 Mar 2012 20:11 #35254 by j999pre
Replied by j999pre on topic Re: Show us your flex
Thats alot of travel and height SI. Looking good
Grey pick up Jimny
