Nox's Jimny - from South Africa
  • Nox
  • Visitor
  • Visitor
07 Dec 2012 20:52 #55111 by Nox
Replied by Nox on topic Nox's Jimny - from South Africa
Does the shocks also need to be swapped or only the Coils?
Your Zook looks like I imagined it would so yeah.
Thanks again for the help Dirtydogz!
07 Dec 2012 20:53 - 07 Dec 2012 23:43 #55112 by dirtydogz
Yes mate the longer ones go on the front, if one of the front springs is a little longer than the other that go on the drivers side, no just the springs.
It's a good job your on this forum then.
We are here to help .
This is the link to auszookers. auszookers.com/forum/index.php?&sid=67f7...9129f36e47df183f5d31
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 07 Dec 2012 23:43 by dirtydogz.
The following user(s) said Thank You: Nox
  • Nox
  • Visitor
  • Visitor
07 Dec 2012 21:06 #55114 by Nox
dirtydogz wrote: Yes mate the longer ones go on the front, if one of the front springs is a little longer than the other that go on the drivers side, no just the springs.
It's a good job your on this forum then we are here to help .
Dirtydogz, you are a legend mate!
Need to now hear what the installer has to say! :angry:
Probably not going to be able to do it tomorrow but I'll post feedback.
07 Dec 2012 21:12 #55119 by dirtydogz
Your welcome mate good luck ;)
  • Nox
  • Visitor
  • Visitor
08 Dec 2012 08:00 #55131 by Nox
OK. I climbed under the Jimny and had a good look.
The installer definitely made a mistake. Long coils are in the back. Then i saw 2 tags still on the coils that was installed in the front. Googled the part number and indeed. "150kg - constant load bearing - REAR COILS"
Phoned up the installer and said that they def made a mistake as that part number needs to be in front and i must bring it in for them to correct. I'll be taking it on Monday.
Is there ANY way they could have made a mistake with Shocks as well?
08 Dec 2012 15:58 - 08 Dec 2012 16:15 #55147 by dirtydogz
No Nox the the shock are different as in the photo.
And you can the different in the length of the springs.
Sounds like money back time from the fitter, for the time you wasted going back for a second time. ;)
Last edit: 08 Dec 2012 16:15 by dirtydogz.
