my jimny
- wanderinstar
- Visitor
11 Mar 2012 17:38 #35296
by wanderinstar
Replied by wanderinstar on topic Re: my jimny
Yes I have But as has been said we shouldnt need them, But it is always easier the higher you can get it, Saves scrabbling around on your back. Are you buying the Wild Country kit or the Disco damper.?
- BIG-P
- Visitor
11 Mar 2012 18:50 #35304
by BIG-P
Replied by BIG-P on topic Re: my jimny
Just ordered the kit from Martin and the damper from ebay both listed above.
Yes i'm a tight Yorkshireman and gone for the cheaper option
- BIG-P
- Visitor
11 Mar 2012 18:53 #35305
by BIG-P
You show me how to go on and i'll do it.
Just need guidence !
wanderinstar wrote: Yes I have But as has been said we shouldnt need them, But it is always easier the higher you can get it, Saves scrabbling around on your back. Are you buying the Wild Country kit or the Disco damper.?
- wanderinstar
- Visitor
11 Mar 2012 20:41 #35314
by wanderinstar
Nothing wrong with that, i am just the same. Let me know when the parts arrive and we will get it sorted. Come over here one evening or a Sat morning.
11 Mar 2012 21:14 - 11 Mar 2012 21:17 #35319
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Re: my jimny
BIG-P just fit the bracket the same way as in Martins photo as the disco damper is a bit longer than the trail master damper, and you will need to cut down the threads on u bolts a little so it don't rub on the damper.
This is the one fitted on my jimny.
Attachment DSCF1594_2012-03-11.JPG not found
2002 JLX Soft Top
Last edit: 11 Mar 2012 21:17 by dirtydogz.
The following user(s) said Thank You: BIG-P
- BIG-P
- Visitor
12 Mar 2012 07:06 #35331
by BIG-P
Dirtydogz,.what exactly it fitted to on the right ?
Is the hole already there?
Cheers
Cheers
