Back in Black
- Back in Black
- Visitor
29 Jan 2012 16:15 - 29 Jan 2012 16:31 #32113
by Back in Black
Back in Black was created by Back in Black
Been meaning to get a "My Jimny" set up for a year!! Finally got most of the photos together so here goes...
Y reg Hard Top, came to me completely standard late September 2010. Didn't take a picture of him till a month later..
I got some Fourtrak wheels with general grabber AT's (235's I think) on. The rears went on no problem - the fronts were catching on speed bumps. Out with the hack saw....
In April 2011 got some 1.5" spring spacers and 32mm wheel spacers from Bits4Vits. Made a heck of a difference to the handling (wheel spacers positive, spring spacers not so positive). More hack sawing...
Then got the rear shock relocators - this made the ride much more agreeable. This kept me quite for a bit, then saw the BigJimny trip to Wagtails!! So next came the 2" body lift (after fitting the extended break lines of course)...
Looks good, rides good - but had some hassle fitting the lift (mainly because I live on a hill - plus rain - plus lack of experience - thanks to advice from Renard I learned to release the steering column and the break line junction, once this was done the rest was easy), ahem...
Then got one of Martins steering damper brackets and a landy disco damper + some 275 knobblies. Then it was off to Wagtails for my first Jimny off road experience...more hack sawing....
Thats the build so far. All my money has gone on repairs since then - new clutch (burnt out at wagtail), recovery equipement (used every trip since), new brakes, spot lights and repairing reversing lights! Need a new back door too after hitting a tree!!
Saving up for 3" suspension kit next (provided nothing else breaks) plus proper recovery point welding on. Oh yes, and a new back box....well will cut it off anyway...
I'll keep you posted.
Attachment IMG_0123.jpg not found
Attachment IMG_0137.jpg not found
Attachment IMG_0165.jpg not found
Attachment IMG_0148.jpg not found
Attachment IMG_0168.jpg not found
Last edit: 29 Jan 2012 16:31 by Back in Black. Reason: Typos
- viciouspenguin
- Visitor
29 Jan 2012 17:01 #32117
by viciouspenguin
Replied by viciouspenguin on topic Re: Back in Black
lol, I can't think of a more perfect example to demonstrate the addiction and subsequent costs of driving and modifying 4x4 vehicles.
Welcome to the club
Welcome to the club
- Nivo
- Visitor
29 Jan 2012 21:13 #32156
by Nivo
Replied by Nivo on topic Re: Back in Black
looking good!
how the jimny off road with 235? are you with samurai t-case?
- myers647
- Visitor
29 Jan 2012 21:27 #32157
by myers647
Replied by myers647 on topic Re: Back in Black
- Back in Black
- Visitor
30 Jan 2012 06:21 #32164
by Back in Black
Replied by Back in Black on topic Re: Back in Black
Hi Nivo thank you - have had no big problems with the tyresize - still standard t-box. I think I should swap the box though, on steep muddy hills 1st gear low gives no run up speed, but 2nd not low enough and it stalls. Of course this might be me rather than the wheel size . Still goes up hills I can't walk up!!
Hey Myers647 - how/where do they mount at the front?? Sound interesting. I've got a tow bar for the rear (in the garage), so interested in the front. I loop the straps around the chassis ends at the moment.
- Back in Black
- Visitor
30 Jan 2012 08:01 #32173
by Back in Black
It's partly your fault vicious, you kindly took me through the woods at wagtail in silver - I'm only trying to emulate Silver......
Hose pipe breathers need fitting next:
View from drivers seat while trying to see if Jimnys float.
Attachment CIMG7362_2012-01-30.JPG not found
Time to create page: 0.144 seconds
