Darth's Jimny
  • kevant
06 Apr 2010 10:08 #3056 by kevant
Replied by kevant on topic Re:Jimny
sorry about that i got confused about that where i live is close to a place called silverdale not far from arnside and i thought that was the place you were on about.
07 Apr 2010 13:53 #3066 by kirkynut
Replied by kirkynut on topic Re:Jimny
darthloachie wrote:
kirkynut wrote:
You've done well - as long as it's not full of rust - all those bits are expensive!!! Looks like it had a Warn 8274 on the front given the cut out on the bonnet and the sticker!
That would have been as powewrful as the engine! It could have dragged it's self about rather than driven!
When you get a winch, have a measure up width wise as it looks like your bumper requires the winch to sit between the chassis rails rather than on them and winches with external brakes may not fit! My Superwinch doesn't and had to go on top.
Have fun with your new toy!!!
What winch do you recomend that would fit between the chasis rails then?
I think Martin's is sat between them and he uses a Champion with brake in the drum I believe!?! Is this right Martin?
You're best bet is to look at the spec of a winch before you buy it. An 8274 is a bit of a different animal to most others and the mounts are on the front rather than having "feet" mounts which are obviously underneath.
I think most makes where the brake is in the drum will fit.
Mine is mounted on top of the chassis rails for this reason but this means it has to stick out further, which in turn effects my approach angle a little.
Your bumper may be made like mine allowing you to do as I have putting it above.
Kirknut
07 Apr 2010 13:56 #3067 by kirkynut
I just stuck a reply on and it has somehow gone to the start of the thread!
No idea how I did that!!!
  • darthloachie
07 Apr 2010 16:49 - 07 Apr 2010 16:51 #3073 by darthloachie
Replied by darthloachie on topic Re:Jimny
how has it done that oh well
Last edit: 07 Apr 2010 16:51 by darthloachie.
  • guillaaaume
04 Sep 2010 17:37 #4528 by guillaaaume
Replied by guillaaaume on topic Re:Jimny
Nice job! I guess it can take you anywhere and never getting stuck lol.
  • darthloachie
04 Sep 2010 20:31 #4534 by darthloachie
Thanks
not really got stuck yet
but need to get a winch for when I DO! :S
I just keep breaking things instead like the rear prop and front disc caliper :blush:
Time to create page: 0.214 seconds
