Kirkynut's Jimny (aka Daddy's Tractor) - The Evolution continues...
  • helijohn
02 Jan 2014 21:17 #98801 by helijohn
kirkynut wrote:
The snorkel needs to be sealed properly
I was actually thinking of a rotatable sealed joint, can't think of anything that would do at the moment, something like a scaled up rotating water sprinkler.
02 Jan 2014 21:37 #98803 by kirkynut
Mud_Muppet wrote: Kirkynut really really like the cage you have on you Jim jam, I remember reading somewhere that it's a custom one, could you tell me where abouts it was made and by who, looks like its welded to the chassis on the rock sliders and then the rest is bolted on ? I've got a Kap internal cage, but Also fancy a external to protect the jimny !
Many thanks Dan
Thank you!
It was made by a good friend of mine who has a welding & fabrication business. I often go over to.his workshop on a Saturday if I'm not working & my Mrs is working to help out and learn some fabrication skills. Most times I go over he's working on someone in our local club's offroader.
He has done many cages for Landrovers but they are quite simple due to their square lines compared to Jimjams.
My cage is bolted to Rocksliders that are welded to the chassis. They've taken some direct hits on rocks in the lakes & peaks but are still where they should be and straight!
The cage is made in parts and bolted together in order that if I bend just part of it, it can be unbolted and a new piece made up to replace it. It's done in the same way as Protection & Performance cages.
It sits nice and close to the body and the bends follow the shape of the body closely, which I think is why it looks nicer than KAP or Rhino Rays cages, which are still very good cages.
He tends to only make cages for people he knows rather than commercially as given what it is, if someone expected it to save them and their car in a roll offroad and it didn't they may come back wanting to sue him, as happens. It's more a tree rubbing cage than a roll cage due to not having any cross bracing but linked to an internal cage with cross bracing it would be very strong, but heavy.
There are a few companies in counties near yours that would make you a good cage, such as ORA and you could ask Rhino Ray if he could get one a bit closer to the body.
02 Jan 2014 21:41 - 02 Jan 2014 21:42 #98805 by kirkynut
helijohn wrote:
It's the seal to the airbox and then what do you replace it with when its removed that's the issue really. Also you'll have a hole in your wing not filled by a snorkel.
I don't know when I'd need it either. I could decide to go though a deep ford when laning at any time and wouldn't want to store it in the car just in case, then faff about fitting it.
It's definately a fit it and leave it fitted thing.
Last edit: 02 Jan 2014 21:42 by kirkynut.
  • Mud_Muppet
02 Jan 2014 22:46 #98813 by Mud_Muppet
Replied by Mud_Muppet on topic Kirkynut's Jimny - The Evolution continues...
Thank you!
Kirkynut[/quote]
Thanks for taking the time to reply, i understand the legal sides which you friend could face if some numpty was to sue, shame really because it looks to me one of the best cages out there, really like the bolt on sections, which is simular to my internal cage,
Well if your friend ever mentions making a cage again,let him know that i would be very very intrested in his business
Thanks again and a happy new year to you
Dan
03 Jan 2014 00:41 #98820 by kirkynut
I shall mention it to him and will let you know if he wants to do it. He could have mine to work from. I'll let you know but if you hear nowt it's a no!
06 Jan 2014 17:29 #99402 by kirkynut
I've bought one of these from Thunderpole for the Jimjam:
www.thunderpole.co.uk/switches-filters/r...ntenna-splitter.html
I hope it will help keep the radio reception on our Lakes Greenlaning Holiday later in the year as the standard Ariel is busted and only works in good reception areas.
I've also treated the Jimjam to a new CB Mic and Mic holder as the clip is busted off the old Mic so it spends it's time on the floor in the passenger footwell.
Just waiting for it all to come in the post!
Also made a big old purchase from the BigJimny Shop today of service parts. I'm gonna throw on some new Kingpin Bearings and Front Wheel Bearings before the Lakes Holiday to help ensure a smooth time - even if the lanes are anything but smooth!
I may or may not be sorting a snorkel too. I know I keep banging on about them but I really want it to look professional and not DIY. If I can't see a way of doing it nicely, I won't do it at all. I've survived this far without one!
Time to create page: 0.232 seconds
