replacing fuel tank
  • tony-a1
18 Jan 2011 20:20 #9954 by tony-a1
replacing fuel tank was created by tony-a1
NOW ONLINEFresh Boarder
Hi how big a job is replacing a jimny 51reg fuel tank,and how long would it take roughly,for a novice mechanic?.Cheers Tony
18 Jan 2011 21:32 #9961 by facade
Replied by facade on topic Re: replacing fuel tank
Quite a big job, propshaft off, disconnect filler tube (takes ages, bolt has to be cut) disconnect breather, undo bolts, lower tank, disconnect fuel pipes (needs a special tool I believe), disconnect wires to pump and gauge.
Why are you changing it?
The usual leak is from around the top of the filler spout beneath the rubber filler tube. If you spend half an hour cutting the bolt with a hacksaw blade the filler pulls off, the spout cleans with emery, and you can coat it with Plastic Padding Leak Fix or similar, smooth with fingers, when it cures refit the spout with a nasty worm drive clip, bodge done ;)
  • bertbuckie
20 Jan 2011 09:05 #10017 by bertbuckie
Replied by bertbuckie on topic Re: replacing fuel tank
Dunno if its any interest but one ends on ebay in 11 hours - used but its at like 99p with no bids :)
Time to create page: 0.313 seconds
