Tyre pressure question please
  • Liz
05 Jul 2009 17:28 #936 by Liz
Tyre pressure question please was created by Liz
Hi folks,
Just a quick question about tyre pressures. As you know I've had my Jimny 'Buster' for about 6 weeks now and being female (sorry ladies) I only just got around to checking the tyre pressure!
They all seem to be 30! Which isn't what it says on that plate inside the car on the door pillar. Unladen - which is what he is at the moment - the front is supposed to be 23 and the rear 29!
So what pressure do you folks use for road use only and should I be worried that mine is high? I did look on the tyre itself and that says max pressure 44 so I'm not worried about a blowout but just wanted your expert opinion.
Thanks folks,
Liz
05 Jul 2009 19:03 #939 by mlines
Garages and tyre depots always seem to inflate them to any old pressure. The hight pressure gives a frimer ride and a tendency to have less grip. I use just over 20PSI all around but then I do have off-road tyres
  • Jamie
06 Jul 2009 07:56 #941 by Jamie
Replied by Jamie on topic Re:Tyre pressure question please
Just to eccho Martin's comments i run mine around 20psi but we run larger
than standard tyres.
Manufacturers reccomendations are your best bet stick with what they say
Jamie
  • Liz
06 Jul 2009 15:12 #946 by Liz
Replied by Liz on topic Re:Tyre pressure question please
Thanks Martin and Jamie. I've still got standard tyres so I'll drop the pressure next time I've got the footpump out.
Cheers,
Liz
  • Jamie
06 Jul 2009 16:34 #947 by Jamie
Hi Liz,
Do yourself a favour and buy a proper digital tyre pressure gauge
the footpump's are very in-accurate.
Garage forecourts are rubbish too best bet is a proper gauge.
Jamie
08 Jul 2009 04:10 #961 by kirkynut
I have found about 25 to be a good compromise. I found much lower made the vehicle struggle unnecessarily as the rolling resistance increased on the road and much more makes them too high and loses grip where they swell in the centre of the tread leaving less in contact.
Tesco's sell a cheap digital pressure gauge and I have found it very accurate. At work we have regularly calibrated machines like those at petrol stations and my Tesco digital gauge always reads the same, as does my slightly more expensive but still cheap Halfords one.
I have found the petrol station ones wildly innaccurate and this is probably as they never get calibrated from the day they are fitted, if they are even done then!!!
Time to create page: 0.303 seconds
