No crank sensor on replacement engine
- Andny
08 Jan 2011 15:39 #9111
by Andny
No crank sensor on replacement engine was created by Andny
I have replaced the engine in my jimmy it's a sohc when wiring up the new engine I realised there is no crank sensor
are all cranks the same with a pick up on so I can just change sumps or do I need to take it back out and find another engine
any help would be greatly appreciated ANDY
- jimjiminyjay
25 Jan 2011 23:18 #10366
by jimjiminyjay
Replied by jimjiminyjay on topic Re: No crank sensor on replacement engine
Hi mate i have the same problem after the same silly mistake, did you find out if you can get away with swapping the sump and sensor across? thanks, Jason.
- Andny
26 Jan 2011 06:35 #10367
by Andny
Replied by Andny on topic Re: No crank sensor on replacement engine
Hi yes I've got mine sorted now
you have to swap the oil pump and cams over from the original engine and also the sump
the oil pump has the pick up on it for the sensor and the cam has a different pick up on and needs the original pick up
it's a fair job to do though the guy I got the engine off did the work on mine
hope this helps and you get it sorted anything else I can help with just let me know ANDY
- jimjiminyjay
27 Jan 2011 18:01 - 27 Jan 2011 18:01 #10432
by jimjiminyjay
Thanks a lot for the very fast very helpfull reply, iv got the original bits but starting to lose interest and tempted to ebay it as an ongoing project
Failing that i guess its not as simple as swapping the ecu over? i guess the imobiliser would be the first hurdle, i have all the bits available from the doner car, but the doner was a v reg manaul hardtop and mines a 51 reg auto softop
Last edit: 27 Jan 2011 18:01 by jimjiminyjay. Reason: added text
- Andny
30 Jan 2011 17:48 #10652
by Andny
Hi if your fed up messing with it I would ask a mechanic how much they would charge to change the engine parts over Selling as a project you won't get much for it
You could say sod it and put a diesel in I came close then bottled it due to too much messing about
ANDY
ANDY
- jimjiminyjay
30 Jan 2011 19:24 #10678
by jimjiminyjay
True, fitting the parts i can do myself, cam is easy enough, i had a quick look at the sump and i can see where the sensor goes on the old engine, but looks like it picks up from the bottom pulley? that said the engine i was looking at was in bits, but i shall swap the bits over and get it running i think, thankfully it doesnt owe much money or i would be sad! and your input has been a huge help
Time to create page: 0.282 seconds
