Disk wear patterns - what wrong?
01 Jan 2011 16:14 #8553 by mlines
See the picture below, the disk is only "polished" in the centre band (as is the pad).
What causes this wear pattern?
Attachment sized_IMGP6821.JPG not found
Attachment sized_IMGP6822.JPG not found
  • Keefe
01 Jan 2011 16:27 #8554 by Keefe
Replied by Keefe on topic Re: Disk wear patterns - what wrong?
Just a stab in the dark, are the pads 'bowed' so that just the centre of the pad is in contact with the rotor?
K :)
  • vitara_mad
01 Jan 2011 16:34 #8556 by vitara_mad
Replied by vitara_mad on topic Re: Disk wear patterns - what wrong?
how long have the discs & pads been on for ?????
01 Jan 2011 17:36 #8564 by mlines
They have been on about a year, but that is only about 200 miles of driving.
02 Jan 2011 12:10 #8645 by kirkynut
MUD!
When you've filled it all up with mud the pressure on the pad is more in the centre so when you brake the centre of the pad touches the disc first whilst the est of the pad is still clearing muddy watery grinding past out of the way which is doing what it does best to the pad as it does so.
I had it on my old SJ and now get it on the Jimny - a new set of pads will sort it and clean the disc up - until the next time!
I thought you'd have noticed this before now with all you drive through Martin?
Time to create page: 0.168 seconds
