Death Wobble idea ?????????
  • Gary Whenmouth
29 Dec 2010 21:09 #8392 by Gary Whenmouth
Death Wobble idea ????????? was created by Gary Whenmouth
Has anyone tried beefing up the panhard rod mounts to the chassis as this looks as if it is flimsy. I've a feeling that beefing these up may help cure some problems.
Maybe someone could fabricate a beefed up bracket??
  • biggaz
29 Dec 2010 21:17 #8394 by biggaz
Replied by biggaz on topic Re: Death Wobble idea ?????????
iirc, adamski had trouble with severe wobble which came down to the panhard bush sleeves?
  • Adamski
29 Dec 2010 21:43 #8401 by Adamski
Replied by Adamski on topic Re: Death Wobble idea ?????????
biggaz wrote: iirc, adamski had trouble with severe wobble which came down to the panhard bush sleeves?
Yeah that's right, turned out my brand new adjustable panhard rods and bushes were the cause of my extreme wobble. The car was undrivable and when I spoke to kap (who I bought them from) they said there latest batch of bushes were dodgy. I cut the metal sleeves down by about 7mm and the wobble was significantly improved, however is not 100% cured (although it is now only very slight and not really an issue). I've just ordered a steering damper so will see what that does.
I know what you mean about the weak mounts, the panhard rods take so much strain so will need to be as strong as possible, it's worth trying and letting the forum know as this could fix a very annoying problem which affects most of us (including my mothers totally standard 2005 jimny).
  • Gary Whenmouth
29 Dec 2010 22:40 #8408 by Gary Whenmouth
Replied by Gary Whenmouth on topic Re: Death Wobble idea ?????????
Im definatly going to fit a steering damper once i have paid off my g/f for buying my jimny, currently its off the road after buying it back after selling it a year ago. Just happy to see it back!. I know it has had new panhard rod bushes which the previous owner had to replace as i had fitted some KAP supplied before i sold it which failed. I have all new kingpins/bearings and the car does have a slight wobble between 30-35mph, it does have very big wheels and no steering damper so this needs sorting first. Let me know how the steering damper goes once you fit it, im going to pop into KAP as i pass there often, probs book in my jimny for a makeover! i could easily spend to much as i want the wide arch kit and a full external cage.
  • Adamski
30 Dec 2010 09:43 #8424 by Adamski
Gary Whenmouth wrote: Im definatly going to fit a steering damper once i have paid off my g/f for buying my jimny, currently its off the road after buying it back after selling it a year ago. Just happy to see it back!. I know it has had new panhard rod bushes which the previous owner had to replace as i had fitted some KAP supplied before i sold it which failed. I have all new kingpins/bearings and the car does have a slight wobble between 30-35mph, it does have very big wheels and no steering damper so this needs sorting first. Let me know how the steering damper goes once you fit it, im going to pop into KAP as i pass there often, probs book in my jimny for a makeover! i could easily spend to much as i want the wide arch kit and a full external cage.
No probs, I'll keep you posted. Ive heard mixed reviews about them stopping the wheel wobble, guess I will soon find out :)
  • biggaz
30 Dec 2010 10:08 #8428 by biggaz
mine still has a bit wobble with the damper fitted :-(
Maybe that shows it depends where your wobble is coming from as to if it stops it on your particular truck??
