disconnecting vacuum cystem
- dc5
27 Dec 2010 22:02 #8209
by dc5
disconnecting vacuum cystem was created by dc5
I bought an E10 torx socket and I`m going to set my jimny hubs on permanent lock;)
How would I go about disconnecting the vacuum system and Is there anything I should do when I have the hubs off:unsure:
Are there any little clips or springs that could pop out If I`m not careful:whistle:
jase.
jase.
- ooky_123
27 Dec 2010 23:23 #8215
by ooky_123
Replied by ooky_123 on topic Re: disconnecting vacuum cystem
just lock the hubs.#
You can disable the vac system by simply pulling off the single pipe that connects the inlet manifold to the vacuum actuators (below the battery).
The 4x4 light on the dash will flash though as it will think there is an error.
However, if your front hubs are locked, and you select 4WD via the TX lever, you can be assured the vehicle is in 4x4
- vitara_mad
29 Dec 2010 15:29 #8306
by vitara_mad
Replied by vitara_mad on topic Re: disconnecting vacuum cystem
is there not a way to stop the light flashing ive fitted manual fwh's & although i know they are locked i still find the flashing light anoying
29 Dec 2010 16:31 #8314
by facade
Replied by facade on topic Re: disconnecting vacuum cystem
You can probably do something with the vacuum switch, but easiest would be to block the two pipes that would have gone to the axle, and leave everything else connected.
The flashing light means the vacuum switch doesn't detect a vacuum in the pipes.
Time to create page: 0.147 seconds
