Diff fill and drain plugs
  • Bigchridy
21 Dec 2010 21:38 #7945 by Bigchridy
Diff fill and drain plugs was created by Bigchridy
I'm after some new fill and drain plugs for the diffs on my Jimny. I need to change the diff oils but the fill plugs look knackered! I will probably have to use a chisel to remove them! I've done a quick search on the internet but I cant seem to find any! There isnt a Suzuki dealer near to me so I havent yet had chance to go and price genuine ones up.:(
Does anyone have any part numbers for these or no of a good place I can by them from (preferably online)?
21 Dec 2010 22:10 #7946 by facade
Can't help with the numbers, but I and a couple of others, simply welded a piece of hexagon/cut down bolt onto the end of the plug.
This facilitated removal, and is so good I never replaced it.
  • Bigchridy
22 Dec 2010 19:15 #7984 by Bigchridy
Replied by Bigchridy on topic Re: Diff fill and drain plugs
facade wrote: Can't help with the numbers, but I and a couple of others, simply welded a piece of hexagon/cut down bolt onto the end of the plug.
Thanks mate. Never thought of doing that!:cheer: Once I can get the Jimny back up to work I'll give it a go!
22 Dec 2010 20:08 #7989 by kirkynut
I bought a new rear diff filler plug a while ago due to the same problem you have and will sift through my receipts for a part number when I get chance if you want.
I think it was about a tenner as only Suzuki can charge prices like that but your dealer will know the part number just from the registration number and you'll not get one from elsewhere I doubt.
  • Bigchridy
22 Dec 2010 21:31 #7996 by Bigchridy
kirkynut wrote: I bought a new rear diff filler plug a while ago due to the same problem you have and will sift through my receipts for a part number when I get chance if you want.
If you get chance a part number would be great but dont go out of your way!
If I get chance I'll call Suzuki in Leeds but I'll make sure I sit down 1st!!
I might just weld a nut on them if their going to be stupid money!
23 Dec 2010 05:41 - 23 Dec 2010 05:43 #8004 by mlines
Based on the Year plate of your registration (its a Jap hard top is it?)
Filler Plug: 09248-20003
Drain Plug: 09246-16010
If its a Spanish one then
Filler Plug: 21947-85C40
Drain Plug: 21947-85C50
Last edit: 23 Dec 2010 05:43 by mlines.
Time to create page: 0.178 seconds
