Roof Lights
- ooky_123
01 Jun 2009 13:04 - 01 Jun 2009 13:14 #761
by ooky_123
Roof Lights was created by ooky_123
Well after seeing the pictures of Martins lights and following the thread on Difflock, we have fitted lights to the Jimny.
The lights mount through a piece of steel square tube that used to be part of a roof bar (scrap yard).
The bar is secured to the roofrack bars using some "L" brackets and secured using square "U" bolts.(not shown in the Pix as I need to lower the lamp mountings to reduce the overall height)
The wiring is run through black conduite to a custom fused marine switch unit and will be connected to the second battery after we come back from holidays.
The Lamps are fitted with 100watt Bulbs and also have "halo" led's around the outside.
Jason
Jason
Last edit: 01 Jun 2009 13:14 by ooky_123. Reason: Crap Spelling !
- Baz2236
01 Jun 2009 19:20 #765
by Baz2236
Replied by Baz2236 on topic Re:Roof Lights
They look good got any pics of them on at night, Do you get much glare from them, I had lights on my cage of my old SJ much better up high as they don't get as dirty the only issue i had is the trees used to smash them.
Baz
Baz
- ooky_123
01 Jun 2009 22:06 #766
by ooky_123
Replied by ooky_123 on topic Re:Roof Lights
Not actually had time to wire them up yet. As they are all spot lights and mounted well behind the driver ( about 5" away from the front of the roofbars ) glare should be minimal. Ive tested the glare aspect using a 500watt flood light (mains powered) at night and had no problems.
These lights are all spot lights and will be set to give a spread of 4 point sof light, one off to each side, and the centre two slightly off straight ahead to give long throw illumination.
We have the standard Bumper fogs for low down light and the A Bar lights are 100watt fog too but adjusted to fill the gap when the standard lights are switched from dipped to main beam.
Off on holidays for 2 weeks this week so doubtful I will get around to getting all the lights setup as I want them, but its a work in progress while we wait for rain !! (its too hard and dusty on the plain at present, even the rivers have turned to pockets of water
- bazwidajimny
02 Jun 2009 13:52 #769
by bazwidajimny
Replied by bazwidajimny on topic Re:Roof Lights
thay look good m8 same as mine
dont mind me asking whot size tyres are on your jimny
- ooky_123
02 Jun 2009 17:25 #770
by ooky_123
Hi, tyres are 215r 15's fitted to Dahatsu (sp) rims.
- gorkur
03 Jun 2009 23:03 #772
by gorkur
Replied by gorkur on topic Re:Roof Lights
Holy mother of awesome.. My Jimny wants to be just like yours when it grows up :woohoo:
Time to create page: 0.174 seconds
