oil warning light
- chrisp4u
- Visitor
14 Dec 2010 03:45 #7515
by chrisp4u
oil warning light was created by chrisp4u
Heya everyone
Need some help, just bought a 2001 jimny, drives and runs perfect, only problem seems to be that when I brake the oil warning light comes on, have checked the oil level and this is fine, any ideas???
Thanks.
Thanks.
- adamjimny
- Visitor
14 Dec 2010 06:38 #7519
by adamjimny
Replied by adamjimny on topic Re: oil warning light
dodgey oil pressure swithch ie looses pressure when braking with the slowing down motion?
- chrisp4u
- Visitor
14 Dec 2010 12:14 #7534
by chrisp4u
Replied by chrisp4u on topic Re: oil warning light
Is it a serious problem? I mean will it do any damage if its not sorted? Is it an easy job that I could do myself?
Thanks chris
Thanks chris
14 Dec 2010 12:16 #7535
by ooky_123
Former owner of Little "Ooky", who has now started a new life in Shetland
Replied by ooky_123 on topic Re: oil warning light
if you are 100% certain you have oil and pressure under normal circumstances, I wouldnt worry too much about it ..,. probably a sensor faulty.
Ive not had to change one of these yet, so cannot comment on the complexity of it, however I wouldnt panic (Personally)
14 Dec 2010 19:18 #7561
by kirkynut
Replied by kirkynut on topic Re: oil warning light
I think it's probably the oil pressure switch playing up and that you have good pressure but could be the oil pump not working well enough - perhaps replace the switch and see if it fixes it - they can't be that expensive but I've not looked to see where it is to know how hard they are to change - used to be on the side of the block on my old SJ and just screwed in.
Time to create page: 0.173 seconds
