Ring & Pinion gears
- jimny5
12 Dec 2010 21:46 #7411
by jimny5
Ring & Pinion gears was created by jimny5
hiya,
does anybody know where you can get new modified Ring & Pinion gears for jimny to sort gearing out,i;ve found ones for sjs on lowrange.com but not jimnys-do they fit jimny diffs?
help would but great
thanks
thanks
- zukhunter
13 Dec 2010 06:54 - 13 Dec 2010 06:55 #7416
by zukhunter
Replied by zukhunter on topic Re: Ring & Pinion gears
i think the best way is to fit a rocklobster to sort out gearing ,i havent heard any mods like the vit r&p fitted to the sj to strenghten the diff
maybe someone along soon might be able to help
Last edit: 13 Dec 2010 06:55 by zukhunter. Reason: spelling
13 Dec 2010 07:19 #7418
Replied by mlines on topic Re: Ring & Pinion gears
It depends on the model of Jimny that you have.
If you have a look here
www.bigjimny.com/images/documents/transferboxratios.pdf
I believe that the diff ratios on the later 2005+ VVT engines are lower so there would be some gain if you fitted these.
- zukhunter
13 Dec 2010 17:31 #7473
by zukhunter
martin would these be a straight swap or alot of modding
- jimny5
13 Dec 2010 21:10 #7491
by jimny5
i already got rock lobster but with my 33in kumhos in could do with being improved
and if i get new ring and pinions i would improve the gearing in low and hi,
it is fairly simple swap,just remove diff and strip down and rebuild with new gears,
martin do you know if sj diffs are similar to jimny.
Replied by jimny5 on topic Re: Ring & Pinion gears
Attachment pgrgbox.gif not found
- jimny5
13 Dec 2010 21:13 #7492
by jimny5
i have a 99 model.
