Fanbelt keeps slipping off?
18 May 2026 09:31 #264458 by facade
Replied by facade on topic Fanbelt keeps slipping off?
Take the belts off, grab the outer rim of the pulley and pull hard from one edge as if you are flipping the rim off, if there is any noticeable movement you need a new pulley. (I'd bet as much as half a Freddo that there will be and you do)
The following user(s) said Thank You: elCookieMuncher
18 May 2026 12:48 #264459 by elCookieMuncher
Haha! That did make me laugh.
I'll go give that a try shortly and report back...I was about to ask how do I see if it is the wheel but you've explained that perfectly. The only annoying part is I just redid the radiator and put new fluid in it, so it seems that will need to be drained out again.
I suppose if the Crank isn't wobbly, then it must be the alternator being misaligned....if it still even works after it went for a swim that is.
18 May 2026 15:15 #264460 by elCookieMuncher
I do believe I owe you half a Freddo,
Took the belts off, and put a slight amount of effort into wiggling the Crank wheel, it moved quite happily without much effort...so good news you found my problem!
I'll be buying a new one and throwing it in asap.
Thanks again
18 May 2026 22:13 #264467 by elCookieMuncher
Just to ask the question. Do I only replace this part? Or are there other parts I should be replacing as well? You mentioned the rubber Laminate, does that come with this bigjimny.com/store/jimny-gen3/crankshaft...-generic-m13a-engine or is that an additional item I need to get too?
19 May 2026 05:41 #264470 by Lambert
Replied by Lambert on topic Fanbelt keeps slipping off?
It will depend on how equipped you are for getting the pulley bolt off. They are designed with a built-in flange washer and consequently the available surface area for rust can make getting them out an angry grinder job especially if you don't have access to a heavy impact wrench and even then it's not a guarantee that the bolt will cooperate. I don't know that I would necessarily order a new bolt with the pulley but I have a second jimny to use for a few days if I were to need it. As for the actual pulley the laminated bit is the ring you can see on the face of the pulley, it's one complete assembly as supplied. Just expect the crank pulley bolt to fight you is the main advice.
06 Jul 2026 23:23 #264872 by elCookieMuncher
Hi everyone.
Just wanted to post and update and say thanks for the advice. The crank wheel was indeed very much broken, I applied a slight amount of force trying to pull it off and the outer rim separated from the inner rim.
I replaced the cranks wheel after a battle in removing the centre bolt, slapped a new one one, and good news she drives like a Dream again.
Even better news, despite me overheating the engine so badly, the engine is still perfect. No oil leaks, no boost issues, no blown head gaskets.
Time to create page: 0.454 seconds
