Gen4 coil springs on Gen3
11 May 2026 16:11 - 11 May 2026 16:13 #264405
by MattHE
Gen4 coil springs on Gen3 was created by MattHE
Hi All.
Quick question - I fitted a nearly new set of Gen4 springs on my Gen3. My car now sits better and rides better. When doing the swap over I noticed the Gen4 springs have fewer turns in the coil of each spring, and they do seem to compress a little more quickly than the old Gen3's. Is that my imagination or simple physics and to be expected? I regularly carry loads in the back or in a roof box, so maybe I would have been better fitting new Gen3 spings?
Your thoughts would be appreciated.
Cheers,
MattHE
Cheers,
MattHE
Last edit: 11 May 2026 16:13 by MattHE. Reason: corrections
- Thank you received: 2001
12 May 2026 03:27 #264409
Replied by Lambert on topic Gen4 coil springs on Gen3
As long as you have good condition dampers to go with the spring refresh then you will be ok as the gen3 has always been relatively over damped. If however the dampers are older high mileage they may allow more rapid body movement which can take a bit to get used to. As long as you keep the roof load to the specified 30kg and remember to accommodate it in your driving decisions it shouldn't too much affect.
12 May 2026 11:29 #264411
by Busta
Replied by Busta on topic Gen4 coil springs on Gen3
Fewer turns means a stiffer spring. More turns make a spring softer. I have gen4 springs on my gen 3 which carries tools and does loads of towing. I feel like they support heavy loads better than the original springs did. The gen 4 shocks are definitely worse than gen 3, though.
12 May 2026 17:09 #264414
by MattHE
Replied by MattHE on topic Gen4 coil springs on Gen3
Thanks Lambert and Busta for your replies. I changed all round to the low mileage Gen4 shocks that came with the springs, so it's interesting what you say Busta. I'll look into an alternative set. I did try a spare set of Rough Country's on the rear but the ride was much too harsh for me. Any recommendations for a road biased damper?
I've probably been over the 30kg roof box limit once or twice (cough cough), but no adverse affects, and no rally driving. I'll remember for the future though...
Cheers guys.
Matt
Cheers guys.
Matt
13 May 2026 12:39 #264423
by Busta
I've previously had Monroe dampers and they were good without being harsh. Bilsteins seem to be the optimum choice, I'll be getting a set when funds allow.
Time to create page: 0.199 seconds
