Sporadic running hot, please help!!!
20 Apr 2026 08:43 - 20 Apr 2026 08:44 #264273
by facade
With the cost of gaskets and the work involved, getting the head faced to be sure that it is flat would be A Very Good Idea. You might get away without, or the new gasket may let go quickly.
You might as well make a week of it and service the valves, do the tappet clearances etc.
Replied by facade on topic Sporadic running hot, please help!!!
Head gasket or a cracked head (unlikely)
To answer your questions... the overflow tank does not return to level, there is a hissing when opening the radiator cap.
Last edit: 20 Apr 2026 08:44 by facade.
21 Apr 2026 07:46 #264287
by Lee
Replied by Lee on topic Sporadic running hot, please help!!!
After much trial, research and interviewing several shops, I dropped it off at the local dealer. Very nice guy and mostly very knowledgeable. He basically reiterated everything you folks mentioned thus far. He will go through the engine in detail again to confirm my findings. The head will be removed, taken to a machine shop for a slight polish and reassembled. The head will be checked for any issues and repaired as necessary, although he doubts he will find anything as he's yet to see any head damage on the DOHC engine with chain.
As for background, I've been living in Greece for 7 years... coming from the USA, I have been involved in the auto manufacturers level as a career. What I've observed here is that almost all makes, models sustain head gasket failures. This must be a "pandemic" of sorts here as I have never seen so many head gasket failures back home. At the dealer, there was a Swift with the same engine as the Jimny, mounted sideways, A Baleno as well as a Vitara with a 2.4. They all had the head removed for gasket failures... Hence my aforementioned description... As mentioned I bought the car used, first thing I did is go through it thoroughly, I completely drained every fluid and replaced with new. As for the cooling system, it contained a mixture of water and what they call here "PARAFLU", which was explained to me as a coolant of sorts. I replenished with a 50/50 mixture of BLUE fluid, which I brought with me from the US, specifically formulated for all aluminum Japanese engines.
In the cumulated 155,000 km, I have operated well, no abuse or misuse. It has performed well under in temperatures exceeded 45C under load, climbing steep grades ad all else, the geography here is a mixed bag of everything. I was taken by surprised to experience the sudden head gasket failure...
I await a call from the dealer as to progress and will update herein as necessary.
Thanks you all for your input and guidance, it is much appreciated!
22 Apr 2026 13:19 #264293
by Lee
After several hours of compression testing, pressure testing the cooling system, and some disassembly, the waterpump exhibited leak from the wheel hole, replaced the pump, and reassembled using with new belts. Pump showed free spinning and not seized. We decided to bypass the heater core and test drove again. The heater core is not restricted but there is very little flow out. An extended test drive on some steep hills and the temp gauge as well as digital instruments connected to the diagnostic port showed normal operation throughout. Considering its summer, I will make a good bypass and run it this way until I have time to source a heater core and time to install...
Once again, my thanks to all for your input on this topic!
Should anything new present itself I will update as necessary!
Best regards,
Lee
Best regards,
Lee
Time to create page: 0.211 seconds
