Tyre presure waring light
03 Apr 2026 12:53 #264185
by Landrover
Tyre presure waring light was created by Landrover
Hi
My 65 reg Jimney is fitted with TPM warning light
The recomended pressure is 26PSI i find this is to hard , If I reduce the psi the idiot warning light activates
ANY ideas how to get rid of the warning light E>G remove the fuse
Thanks
Thanks
- Roger Fairclough
- Thank you received: 225
03 Apr 2026 16:04 #264186
by Roger Fairclough
Replied by Roger Fairclough on topic Tyre presure waring light
Scroll down the recent strings until you find "TPMS".
Roger
PS What's a landrover?
Roger
- Thank you received: 672
03 Apr 2026 16:54 #264187
Replied by DrRobin on topic Tyre presure waring light
The TPMS warning is fixed at about 23-25 PSI, so if you run the 26 PSI recommended then on cold mornings you will most likely see the warning.
There is no way to change the threshold and it’s an MOT failure if the TPMS isn’t working. Not sure what pulling the fuse will do, probably light the ‘Check Engine Light’ but it will certainly raise a fault code.
You can get TPMS Spoof devices that feed the TPMS a constant pressure on all four wheels (I have the Iron Gates unit for my off-road wheels, no sensors) but I don’t know how practical it is to have both the Iron Gates and real TPMS sensors at the same time, have a look at their website, search Iron Gates SpoofTPMS.
04 Apr 2026 14:31 #264189
by Landrover
Replied by Landrover on topic Tyre presure waring light
Thamks for the info
P.S a landrover defender (old Model ) is an expensive Jimny
