2004 Jimny M13A High Temp after recon head and head gasket replace
25 Mar 2026 04:41 #264103 by Kappy
I've just recently replaced head gasket and recon head on my new to me 2004 Jimny M13A.
After re-nstalling everything I have done several short trips near home of approx 8 km with temp sitting in middle.
I live in a remote rural location about 30 minutes from nearest town, today did a run into town.
After about 20km sitting on approx 80-90km/h the temp gauge starting rising to the level in pic.
I turned on heater lever and temp starting dropping so did my speed as I entered town limits.
On returning home temp approx middle of gauge and after about 20 minutes starting rising again, turn heater again temp drop slighty.
Temp never went over the level depicted in pic.
Have I missed something.
Didn't look at Thermostat or replace radiator.
Radiator look OK although didn't test other than flushing with hose.
Any guidance please.
TIA
Kappy
25 Mar 2026 07:13 #264105 by CelicaRacer
Seems like you have an air lock somewhere, I would bleed it again
1999 Suzuki Jimny
1990 Toyota Celica garage queen
1996 BMW e36 touring track car
2007 BMW e61 520d touring
1998 BMW Z3 Drift Car
The following user(s) said Thank You: Kappy
25 Mar 2026 07:30 #264106 by Busta
The coolant systems on these does take a bit of time to bleed up. Run it from cold with the radiator cap off until the thermostat opens and keep topping it up. Squeezing the top radiator hose helps to burp a bit of air out.
25 Mar 2026 13:51 #264115 by Kappy
I'll try that again before I remove the thermostat.
I don't recall the thermostat opening after topping up.
Maybe need to be a little more patient.
Does it take a bit for it to open?
25 Mar 2026 19:42 #264117 by Busta
Yes it takes a while. You can feel the warm water circulating the rad when it opens.
26 Mar 2026 01:08 #264120 by Kappy
Ran at idle/fast idle for 20 minutes, didn't any evidence of thermostat opening.
Feel thermostat maybe faulty, possibly responsible for earlier over heating issue.
Will remove when called down.
Worthy of note, I was unable to get 5 litres of coolant in system, borderline 4 litres.
More to be revealed.
Thanks
Kappy
Time to create page: 0.388 seconds
