Rocker cover bolts - torque and order?
01 Mar 2026 22:55 #263921 by smalljay32
Does anyone happen to know please what the torque and order in which one should ratchet the bolts on the rocker cove?
This is for a 2006 M13A VVT.
Many thanks!
Proud father of Jep the Jimny (2006 VVT)
01 Mar 2026 23:16 #263922 by yakuza
The cover is just M6 bolts (?) and a rubber gasket. No particular order or special torque needed in my opinion. 4-5Nm should do it if its M6.
I would recommend to buy a new special gasket as they turn hard after ten years.
Not to be confused with the cylinder head bolts.
10 Mar 2026 15:37 #263955 by smalljay32
Thank you for your help! I was actually changing out a worn out gasket funnily enough.
Time to create page: 0.220 seconds
