Heater not doing much heating
21 Jan 2026 13:14 #263505
by Busta
Heater not doing much heating was created by Busta
I've always found Jimny heaters to be pretty incredible, but recently mine has become rubbish. The fan works in all speeds and airflow is great but it get's luke-warm at best.
The control cable on the side of the HVAC unit is connected and operating properly.
It has a new thermostat installed correctly.
I've flushed the heater pipes out with a garden hose and they flowed fast and clear.
The water pump is in good condition.
It's not using any coolant or blowing bubbles in the rad.
Anything else I could look for?
- Thank you received: 662
21 Jan 2026 14:05 #263507
Replied by DrRobin on topic Heater not doing much heating
I took the control knob off mine to change the bulbs and for about a year afterwards my heater was lukewarm, it seems I didn’t quite get the control cable in correct place.
When I took it apart again and double checked the cable position there was only a slight bit more cable and it made a bit of a difference, but not convinced it was as hot as it used to be.
The usual culprits are a sticking thermostat (open), sludge in the heater matrix or air trapped in the matrix, but you seem to have covered these.
Robin
Robin
- Thank you received: 1971
21 Jan 2026 16:54 #263508
Replied by Lambert on topic Heater not doing much heating
There might be a blockage before the matrix, could be worth flushing through the block and out of the matrix feed and return pipes?
21 Jan 2026 18:37 #263510
by Busta
Replied by Busta on topic Heater not doing much heating
Good point Lambert. I'll give that a try.
22 Jan 2026 19:44 - 22 Jan 2026 19:45 #263521
Replied by yakuza on topic Heater not doing much heating
Mine is not very good now as both the AC and heater matrix are full of sand and dust on the air side, from driving stupid places without the filter.
Going to flush, blow air and vacuum it thru any openings I can find come spring.
Last edit: 22 Jan 2026 19:45 by yakuza.
Time to create page: 1.709 seconds
