Gen 3 Suzuki Jimny 1.3 (M13A) – Cranks slowly, no spark
17 Jan 2026 16:37 #263427
by lulielmo
Gen 3 Suzuki Jimny 1.3 (M13A) – Cranks slowly, no spark was created by lulielmo
Hello,I’m looking for help troubleshooting a Suzuki Jimny 1.3 petrol, manual, 4WD that cranks but will not start.
I’ve been working through this quite methodically over a longer period and am now running out of ideas on what the next logical step should be.
Vehicle details
Symptoms
What has been checked / replaced
✅ New battery
✅ Starter motor cranks every time
✅ New crankshaft position sensor (CKP)
✅ New camshaft position sensor (CMP)
✅ RPM signal visible in OBD live data (approx. 120 rpm while cranking)
✅ Aftermarket RPM limiter from previous owner has been electrically bypassed and completely removed from the circuit
✅ Spark test
Wiring / electrical observations
Grounds / voltage drop
Questions / help needed
John
Vehicle details
- Model: Suzuki Jimny
- Model year: 2004 (first registered 2004-08-23)
- Engine: 1.3 M13A DOHC 16V VVT
- Power: 60 kW / 82 hp
- Fuel: Petrol
- Transmission: Manual
- Drivetrain: 4WD
- VIN: JSAFJB43V00186004
Symptoms
- Starter motor cranks the engine, but:
- cranking speed is unusually slow
- engine does not fire at all
- No improvement when jump-starting from another running vehicle
- Brand new, fully charged battery fitted → no change
✅ New battery
✅ Spark test
- Spark plug removed and grounded to engine block
- Occasional, sporadic sparks observed, at most one per test but not during every crancing attempt
- No consistent or repetitive spark pattern during cranking
- 12 V supply present
- Ground OK
- ECU trigger signal tested with LED test light (difficult to verify reliably due to sealed connector)
- TPS
- MAP
- ECT
- Battery voltage
- Previous wiring repairs found in the harness to the COP coil on cylinder 2 (all three wires spliced)
- No similar splices found at coil for cylinder 4
- No clear correlation to the current fault found so far, but noted
- Voltage drop measured between battery negative and engine block during cranking: ~0.19 V
- Starter still feels sluggish despite this
- Suspicion remains around grounds, main cables, or starter motor condition
- Are there known ground points or main cables on the Jimny M13A that commonly cause slow cranking and no-start issues?
- Common faults that give an RPM signal but unstable or no ignition?
- Next logical steps:
- measure voltage drop on positive cable to starter?
- mechanical inspection / bench test of starter motor?
- ECU or immobiliser related issues?
- Any Jimny-specific quirks I may be missing?
John
- Thank you received: 1996
17 Jan 2026 17:00 #263429
Replied by Lambert on topic Gen 3 Suzuki Jimny 1.3 (M13A) – Cranks slowly, no spark
Wel om to the forum.
First port of call have you checked the immobiliser is reading the key and behaving itself?
17 Jan 2026 19:15 - 17 Jan 2026 19:17 #263438
by facade
Replied by facade on topic Gen 3 Suzuki Jimny 1.3 (M13A) – Cranks slowly, no spark
Most important question- Was it running perfectly when you parked it yesterday, or did it last run for you ages ago, did someone else last use it or even did you buy it and have never had it running yourself?
It could just be cranking too slowly.
Is there any oil in it? (We though SIL's BMW mini had a lazy starter until we noticed no oil on the stick- BMW minis empty the sump in a few thousand miles)
Is the alternator or power steering seized? Easy enough to drop the belts off to check.
It could be a lazy starter motor. I'd remove it (allow half a day, it is not easy) and strip it down for inspection, replace if there is any doubt, you don't want to take it off again.
Sometimes people drive these cars through deep muddy water that gets into everything causing rusting and seizure of bearings
Once it is cranking nicely, if there is still no sparks you can start checking all the wiring around the coils, and maybe swapping coilpacks.
Last edit: 17 Jan 2026 19:17 by facade.
19 Jan 2026 07:56 #263466
by lulielmo
Replied by lulielmo on topic Gen 3 Suzuki Jimny 1.3 (M13A) – Cranks slowly, no spark
Thanks both – very good and relevant questions and suggestions.
The immobiliser appears to behave normally: the warning light comes on with ignition, then goes out after a couple of seconds.
I also see RPM during cranking in OBD live data (~120 rpm), and I do get occasional sporadic sparks, so the system does not seem to be fully immobilised, as far as I can tell.
To answer what i realize is an important question:
Yes, the engine was running before.
One of my daughters was driving the car when it started making an unusual noise (unfortunately hard to describe exactly). She parked the car and shut the engine off. After that, the engine has not started again. This was in early December.
Oil level has been checked and is OK.
Regarding cranking speed:
The engine cranks very slowly, even with a brand new, fully charged battery. Jump starting from another running car made no noticeable difference. Given your reply, this has made me increasingly suspicious of either:
Starter motor inspection or replacement is now high on my list. I agree that slow cranking could explain why I only see very occasional, sporadic sparks, despite RPM being visible in OBD.
Swapping the two coil packs is also something I can try, although given the slow cranking, I suspect the root cause may be more fundamental.
Thanks again – this is very helpful and gives me a clearer direction for the next steps.
- excessive mechanical load, or
- a starter motor / main power or ground issue causing voltage collapse during cranking.
19 Jan 2026 08:34 #263471
by facade
I just thought- to save taking the starter off, take the spark plugs out and see if you can turn the engine easily from the bolt in the middle of the bottom pulley with a socket wrench.
It should turn easily, if it is stiff then something is partially seized.
If it made A Noise then something is wrong....
19 Jan 2026 09:41 - 19 Jan 2026 09:42 #263475
by lulielmo
That’s a very good suggestion, thanks.
I'll happly avoid removing the starter, or at least postpone it. I will remove all spark plugs and try turning the engine directly from the crank pulley bolt with a socket, to assess mechanical resistance.If it turns freely, that should help narrow the problem back to starter / electrical issues. If it’s stiff, then something mechanical is clearly wrong.
I’ll report back once I’ve done the test.
Last edit: 19 Jan 2026 09:42 by lulielmo. Reason: another typo
Time to create page: 0.260 seconds
