1.3 single cam to 1.5 twin cam
- Arranbaker
06 Jan 2026 00:41 #263291
by Arranbaker
1.3 single cam to 1.5 twin cam was created by Arranbaker
Doing an engine swap from a 1.3 single cam 2000 model to a swift 1.5 engine, has anyone else done this, haven’t yet put the engine in but already know most parts and gearbox aren’t compatible, what about ecu and wiring does this also need to be changed?
06 Jan 2026 14:02 #263301
by Busta
Replied by Busta on topic 1.3 single cam to 1.5 twin cam
No, the G series wiring and ECU are not compatible with the M series engines. You would need to swap a complete wiring loom from a newer jimny. Or go for a standalone ecu. A G16 engine is an easier swap, but still requires an adapter for the gearbox.
- Arranbaker
09 Jan 2026 16:46 #263342
by Arranbaker
Replied by Arranbaker on topic 1.3 single cam to 1.5 twin cam
So a wiring harness and ecu out of a m engine jimny will work with the swift engine?
- Thank you received: 1998
09 Jan 2026 18:05 #263343
Replied by Lambert on topic 1.3 single cam to 1.5 twin cam
Not only an m series ecu but a vvt or not depending on the donor motor. The vvt having a bump on the timing case none vvt being flat across.
10 Jan 2026 00:36 #263346
Replied by yakuza on topic 1.3 single cam to 1.5 twin cam
I would say that not an ecu, but The ECU is needed.
And the harness, immo, and correct Key for the ecu.
For simplicity and to avoid the need to code stuff together I would not bother unless all nescessary items came from one donor.
But then it is not so simple anymore and so I wouldnt do it.
Time to create page: 0.208 seconds
