Gen 3 (98) G13B started rattling underneath - rear Prop? Video
08 Dec 2025 11:55 #263025
by RoryC90
Hi all looking for some help please!
Picked up an old Gen3 about 6 months ago as a bit of a project/start into off-roading. Its since become my daily driver as I love it. Anyway, it's starting to show the odd bit of wear and tear, as to be expected.
Yesterday it started making a tinny rattling sound, from underneath. Sounds like a snapped heat sink, but I've gone underneath a few times and they're all solid. Only doing it while driving, though doesn't appear related to a specific gear. Does appear to happen over bumps too as I coasted the car over a bumpy road and it rattled again. It isn't happening all of the time and I can't seem to replicate the sound when I want to.
Seems to be coming from the rear prop, or something knocking the rear prop which is vibrating and causing a tinny sound. Video below shows knocking on the prop which makes a similar sound and when you wiggle the output shaft on the transfer case it makes a similar sound.
Has anyone seen this before? I presume something in the transfer case is either on the way our or already dead? Is it catastrophic/will it drive a little before addressing it?
Any help or thoughts greatly appreciated
Rory
Youtube short link
Rory
Youtube short link
08 Dec 2025 19:01 #263028
Replied by jackonlyjack on topic Gen 3 (98) G13B started rattling underneath - rear Prop? Video
I would remove the prop shaft
This will give you a little more feel on the joints
Or just buy a good used replacement
I personally would keep using it till my replacement prop arrives
Reason you can replace the uj joint but it sounds and looks like it's the cv type joint that's problematic
09 Dec 2025 14:45 #263031
by RoryC90
Replied by RoryC90 on topic Gen 3 (98) G13B started rattling underneath - rear Prop? Video
Thanks a lot for having a look, I'll get the prop off when I have a free weekend and have a bit of a wiggle!
10 Dec 2025 21:36 #263037
by bryn
Replied by bryn on topic Gen 3 (98) G13B started rattling underneath - rear Prop? Video
Mounts on the transfer case are notorious for rotting away. They often look ok but the rubber comes away from the metal.
Bryn
Bryn
Time to create page: 0.178 seconds
