Bead lockers - Can you get them, do you need them?
25 Nov 2025 21:44 #262917
by benjo
Bead lockers - Can you get them, do you need them? was created by benjo
Hi all,
Is anyone out there running bead lockers? I would imagine that given how light the Jimny is, there wouldn't be a need for it. I'm currious to hear your thoughts on the subject. Can you even get them for the Jimny?
25 Nov 2025 22:29 - 25 Nov 2025 22:31 #262918
Replied by yakuza on topic Bead lockers - Can you get them, do you need them?
Mostly the ones I Seen have been welded to steel wheels on pure off road cars or competition cars.
Depending on rim width and tyre size and pressure if you need them.
I have run 235's BFG MT on 5.5 rims with 0.4 bar pressure and do not need them. And they are not road legal here either.
Last edit: 25 Nov 2025 22:31 by yakuza.
26 Nov 2025 00:31 #262920
by 300bhpton
Replied by 300bhpton on topic Bead lockers - Can you get them, do you need them?
I would say you probably don't need them. And if you are asking if you do, then that probably reinforces the view.
You should be able to quite safely run down to 12-15psi on standard off road tyres on normal rims without any real issue. Which should be fine for many many types of off road use.
You can run lower for sand. Its more rock crawling where you'll be getting a lot of tyre roll and deflection where super low pressures will need a beadlock. Or maybe in the snow, as you could always hit a tree, rock or some other hard object. Sand dunes or beaches you are far less likely.
Another option is to just fit some inner tubes, which would allow lower pressures with less risk. Although many modern tyres don't play nice with inner tubes these days.
26 Nov 2025 07:11 #262923
by saxj
Replied by saxj on topic Bead lockers - Can you get them, do you need them?
I agree. I run my 235 M/T's at 0.4-0.5 bar on the stock rims, in all off-road conditions, and have never had a debead. I have seen it with smaller tyres usually BFG A/T's, but they have been easy to reseat, just with a compressor.Mostly the ones I Seen have been welded to steel wheels on pure off road cars or competition cars.
- Thank you received: 1999
26 Nov 2025 07:27 #262924
Replied by Lambert on topic Bead lockers - Can you get them, do you need them?
Also another point against beadlock wheels is the additional weight in the wheel tyre combination and it's position away from the centre of rotation. It won't help braking or acceleration on road and it will make your suspension work harder. But if you need them then you need them because you are already on terrain that is causing problems with the tyre coming off.
Time to create page: 0.173 seconds
