2023 OME Lift Kit Does Fit 2015 Jimny ??
04 Nov 2025 09:27 #262591
by thewd789
jimny 2015
2023 OME Lift Kit Does Fit 2015 Jimny ?? was created by thewd789
[object Object] My friend has a 2023 Suzuki Jimny with a 2.5-inch Old Man Emu lift kit installed. He now wants to upgrade to a higher lift and is offering to sell me his current kit. I own a 2015 Jimny – will this lift kit fit my model without issues, or are the suspension setups different between the two generations?
jimny 2015
04 Nov 2025 12:24 #262592
by jlines
1986 SJ413JX (Lil Red)
2018 JB43 SZ4
2019 JB74 SZ5 (Gerald)
2023 JB74 LCV
Replied by jlines on topic 2023 OME Lift Kit Does Fit 2015 Jimny ??
Obviously I'm not 100% sure but I know the stock suspension is the same and people have put Gen 4 Stock suspension on a Gen 3 (I sold mine to a Gen 3 owner) Therefore I would assume you can use a lift kit from a Gen 4 on a Gen 3 aswell. The only part that you wouldn't need from the Gen 4 kit would be the headlight light levelling kit.
2018 JB43 SZ4
2023 JB74 LCV
The following user(s) said Thank You: thewd789
04 Nov 2025 13:08 #262595
by fordem
Replied by fordem on topic 2023 OME Lift Kit Does Fit 2015 Jimny ??
If all you're interested in is having it fit, then yes, it will fit, however, it won't be optimized for your car.
OME does not sell a 2.5 inch lift kit for the Jimny, and they do not sell a lift kit per se, they sell a suspension upgrade with components that are selected for the task at hand, with loaded vehicle weight being the deciding factor.
For the gen 4 I think you can choose between three different coils & two shocks for the front, and the same for the rear, with an approximate increase in ride height of 40mm, not 64mm (2.5 inches).
Whatever your friend has, if it's 2.5 inch lift, it's either not OME, it's not OME the way OME would select their suspension, or it's not OME alone, and fitted to a lighter Gen 3, the ride quality would be questionable.
04 Nov 2025 22:39 #262613
by Busta
Replied by Busta on topic 2023 OME Lift Kit Does Fit 2015 Jimny ??
It will fit and work just fine. Gen 3 and 4 suspension setups are the same and the vehicle weights are very similar.
10 Nov 2025 17:53 #262674
by thewd789
jimny 2015
Replied by thewd789 on topic 2023 OME Lift Kit Does Fit 2015 Jimny ??
Quick update – I installed the lift kit today, and everything fit perfectly, one-to-one.The ride quality has improved a lot — the car feels much more stable and comfortable, both on and off road.Thanks to everyone who shared advice and helped out!
jimny 2015
