Jimny JB74 (2019+) – Torque Pro PID for TPMS (tire pressure monitoring)
11 Sep 2025 06:43 #261897 by Maxpole
Hi everyone,I’m trying to read the original TPMS sensor data on my Suzuki Jimny JB74 (2019, EU model) via OBD2 using Torque Pro.With the SZ Viewer app I can already see the raw CAN frames, and I’ve identified some CAN IDs that seem to match the TPMS sensors:
  • 6E664797
  • 6E6647AF
  • 6E6647B7
  • 6E6639D1
The issue is that I can’t figure out the correct formula to convert the bytes into bar/psi. I’ve tried:
  • A/2
  • ((A*256)+B)/50
  • A/100
…but in Torque Pro I only get wrong values (like -1 psi or very unrealistic high numbers).👉 Has anyone here already managed to configure Torque Pro custom PIDs for Jimny JB74 TPMS and could share:
  • The correct Mode/PID or CAN ID
  • Which byte(s) (A, B, C, …) correspond to tire pressure
  • The working formula (Equation) in Torque Pro
  • Any notes about units (bar or psi)
I think this would be really useful for many of us Jimny owners who would like to monitor tire pressures directly on the phone.Thanks a lot in advance 🙏
11 Sep 2025 07:41 #261898 by facade
I'm afraid I can't help except to suggest that the tyre sensor may well be reading absolute pressure, so it's output will be +1 bar if that helps with the calculations.
11 Sep 2025 21:46 - 11 Sep 2025 21:54 #261914 by mlines
I am doing the same but I can't find how to get szviewer to show me raw frames? How can this be done
Last edit: 11 Sep 2025 21:54 by mlines.
11 Sep 2025 21:52 #261915 by mlines
Oh and if I was able to read the frame I would then deflate the tyre and reflate it and watch how the bytes change. Some bits/bytes would not change as they are the battery state and angular velocity etc. so those that do change would be tyre pressure
12 Sep 2025 00:37 #261918 by facade
Is this any help?  There is mention of J1939 standard, which is for heavy vehicles, but it shouldn't be a million miles away
The second byte x 4 is the pressure in kPa  (100kPa = 1 bar)
www.tyrepal.co.uk/wp-content/uploads/202...DULE-USER-MANUAL.pdf
12 Sep 2025 02:20 #261920 by Filipao
Hi, OP, sorry I wasn't much help on Reddit. Please let me know if there's anything else you'd like to know on the TPMS spoof.
Kindest regards, Filipe
Time to create page: 0.262 seconds
