Jimny JB74 (2019+) – Torque Pro PID for TPMS (tire pressure monitoring)
11 Sep 2025 06:43 #261897
by Maxpole
Hi everyone,I’m trying to read the original TPMS sensor data on my Suzuki Jimny JB74 (2019, EU model) via OBD2 using Torque Pro.With the SZ Viewer app I can already see the raw CAN frames, and I’ve identified some CAN IDs that seem to match the TPMS sensors:
- 6E664797
- 6E6647AF
- 6E6647B7
- 6E6639D1
- A/2
- ((A*256)+
/50 - A/100
- The correct Mode/PID or CAN ID
- Which byte(s) (A, B, C, …) correspond to tire pressure
- The working formula (Equation) in Torque Pro
- Any notes about units (bar or psi)
11 Sep 2025 07:41 #261898
by facade
Replied by facade on topic Jimny JB74 (2019+) – Torque Pro PID for TPMS (tire pressure monitoring)
I'm afraid I can't help except to suggest that the tyre sensor may well be reading absolute pressure, so it's output will be +1 bar if that helps with the calculations.
11 Sep 2025 21:46 - 11 Sep 2025 21:54 #261914
Replied by mlines on topic Jimny JB74 (2019+) – Torque Pro PID for TPMS (tire pressure monitoring)
I am doing the same but I can't find how to get szviewer to show me raw frames? How can this be done
Last edit: 11 Sep 2025 21:54 by mlines.
11 Sep 2025 21:52 #261915
Oh and if I was able to read the frame I would then deflate the tyre and reflate it and watch how the bytes change. Some bits/bytes would not change as they are the battery state and angular velocity etc. so those that do change would be tyre pressure
12 Sep 2025 00:37 #261918
by facade
Is this any help? There is mention of J1939 standard, which is for heavy vehicles, but it shouldn't be a million miles away
The second byte x 4 is the pressure in kPa (100kPa = 1 bar)
www.tyrepal.co.uk/wp-content/uploads/202...DULE-USER-MANUAL.pdf
12 Sep 2025 02:20 #261920
by Filipao
Replied by Filipao on topic Jimny JB74 (2019+) – Torque Pro PID for TPMS (tire pressure monitoring)
Hi, OP, sorry I wasn't much help on Reddit. Please let me know if there's anything else you'd like to know on the TPMS spoof.
Kindest regards, Filipe
Time to create page: 0.231 seconds
