Rear fog light for UK registration
06 Sep 2025 15:35 #261864 by FrankFisher99
Hi all, I have a 2010 jap import and to register it just needs a rear fog light - surprised not to see anything on the topic here? I want to keep it OEM so have picked up this secondhand switch; can anyone help me out with a wiring diagram? Im assuming the factory setup uses a relay, if so does anyone have a part number or pic?
11 Sep 2025 17:14 #261906 by Deepak43
Hi,A rear fog light is a legal requirement for vehicles registered in the UK, as it ensures visibility and safety during adverse weather conditions like heavy fog, rain, or snow. It helps other drivers spot your vehicle from a safe distance, reducing the risk of accidents. The rear fog light should emit a bright red light, distinct from the brake lights, and be positioned symmetrically at the rear of the vehicle. Proper functioning and compliance with MOT standards are essential for road safety.  sso id
11 Sep 2025 18:40 #261909 by facade
I don't have a wiring diagram for a 2010 JDM Jimny, but if it is like the UK version then the headlights use a permanent live, with a switched earth.
When the dipped headlights are on, the red & white wire from the column switch is earthed.
So your relay coil goes from a suitable switched live at one end to the red & white wire.
The relay contacts should switch a fused live feed to the foglight, which is earthed at the rear.
You either need one foglight on the centre line or on the right, or a pair symmetrically placed. A JDM has 2 reverse lamps, you could modify the right one to be a rear fog, and fit a UK lens.
You then need a switch to interrupt one end of the relay coil, with a teltale lamp wired so that it illuminates when the relay coil is energised.
The original switch is bizarre and I can't figure it out immediately (the diode looks reversed to me...), just check the wiring diagram out!
11 Sep 2025 19:05 - 11 Sep 2025 19:11 #261911 by facade
I dug out the very late Gen 3 digram, and that switch sort of makes a bit more sense as they've drawn an extra internal wire.
I reckon that the 2 contacts circled in red are the switch, (I don't know why there are 2) and the other is a built in relay contact. (So you don't need a separate relay)
Best that I can deduce from just the diagram  is below
NOTE: THIS IS JUST MY INTERPRETATION OF THE DIAGRAM. (I DON'T HAVE A SWITCH TO TEST) USE AT YOUR OWN RISK. IF THE CAR EXPLODES, BURSTS INTO FLAMES, SUDDENLY TIPS UPSIDE DOWN, GOES BACKWARDS IN FORWARD GEARS OR ANYTHING ELSE ODD HAPPENS I ACCEPT NO RESPONSIBILITY.
So
The light green (4) goes to your fused live
The black (1) & (2) go to earth
Red/yellow (5) goes to the sidelights and illuminates the switch.
Green/Black (3) is the live feed to the foglight
Green/red (6) is the switched earth from the headlights- connect to the red/white from the column if there isn't a green/red.
Probably best to wire up pins 1,2,3,4 &5 and check that the switch illuminates with the sidelights, then try grounding pin 6 and the foglight should switch on & off with the switch, then try connecting pin 6 to the red/white (or green/red)- try lashing this up on your workbench to test it out before you start messing with the car wiring.
Last edit: 11 Sep 2025 19:11 by facade.
The following user(s) said Thank You: FrankFisher99
16 Sep 2025 09:19 #261964 by FrankFisher99
Thanks, yes that is the correct wiring diagram, I had also managed to dig it up elsewhere. My biggest problem was figuring out the pin numbering arrangement, but that is detailed in the official Suzuki manual. I needed that because the switch I bought was a second hand vitara one with different coloured wiring. But, all good now, I installed it with an LED bulb into the empty slot in the right hand bumper light unit. MOT tomorrow, fingers crossed.
16 Sep 2025 18:51 #261972 by facade
Yeah, the first wiring diagram is obviously wrong, as now I figured out the switch from the second, as drawn the first will just ground the live feed when the relay operates and blow the fuse!
Glad it works!
Time to create page: 0.218 seconds
