Brake Issue - Diagnostic Help Required
04 Sep 2025 10:49 #261835 by arthursc
I have a 2008 Jimny ABS VVT with an issue that  we can't quite get to the bottom of.
Symptoms:
Breaks very spongy and foot to the floor almost before we the brakes seem to work. Pumping the brakes seems to give a better outcome , but once you take your foot of the brake to re-apply, then pressure has gone.
New oil, New lines, New pads, shoes and disk all round.
It is symptomatic of air getting into the system and bleeding doesn't resolve the issue.
Also can anyone identify this part that sits below the ABS unit on the near side of the engine?
Thanks in advance, Colin.
04 Sep 2025 12:26 #261836 by Lambert
Could be a bad wheel bearing allowing the disc to push the pads back meaning you have to take up the excess each time?
The following user(s) said Thank You: Darthblaker7474
04 Sep 2025 13:46 #261837 by fordem
Valve assembly, proportioning & differential.
04 Sep 2025 13:49 #261838 by jackonlyjack
You say new discs all round
So you have rear conversion fitted?
Did you unbolt the rear caliper carriers and spin it round the disc to put bleed nipple to the highest point for bleeding
04 Sep 2025 13:54 #261839 by fordem
Generally speaking, this will cause long pedal travel, but not a spongy pedal.  In 50+ years, I've only seen one occasion on which a spongy pedal was not caused by trapped air, and that time it was a brutal "hack job" with butchered pads.
04 Sep 2025 16:24 #261840 by arthursc
We’ve isolated the rear. Blanked off as part of the diagnostics. Still happens with the front. Servo has good seal so not that. Pointing towards the master cylinder.
Time to create page: 0.168 seconds
