Body mount rust repair
- tobywood13
21 Aug 2025 17:39 #261704
by tobywood13
Body mount rust repair was created by tobywood13
Hi all, I’ve recently acquired a 2000 Jimny, which has just failed its MoT on rust to two body mounts and the rear crossmember. Does anyone have any tips for how to sort the body mount? They’re the middle ones (I think), just in front of the rear wheels.
Can these holes be patched or is it better to replace the whole unit. If the whole thing should be replaced, how do you do it? Many thanks, from a new Jimny owner with a hint of buyer’s remorse…
- Thank you received: 2005
22 Aug 2025 03:21 #261709
Replied by Lambert on topic Body mount rust repair
Welcome to the forum. I would expect that to become quite a bit worse once it is cleaned up to good metal so it may well be that the whole thing will need replacing anyway. Good luck.
22 Aug 2025 08:33 #261712
Replied by jackonlyjack on topic Body mount rust repair
Pictures are chassis
Firstly can you do the work yourself?
If not I would say source the mounts from a donner chassis
Then find someone who can do the work
You maybe able to plate up what you have but like Lambert says it could be a lot worse when cleaned up
You could try lamberts engineering for donner parts
Time to create page: 0.159 seconds
