Gearbox fill plug and Spark plug tube oil seals
30 Jul 2025 14:28 #261389
by sj_4x4
Gearbox fill plug and Spark plug tube oil seals was created by sj_4x4
Afternoon all, 2004 Jimny with a G13B engine, some numpty has destroyed the gearbox 10mm square fill plug, no way it's coming out with the box still in the car, before I do this is there another way of filling it ?
Also I fitted some Elring plug tube seals, they were the only ones I could find, the quality of them was terrible so I didn't expect them to last long, and they didn't, can anyone suggest where I can get some decent ones from please ?
Thanks in advance !
Thanks in advance !
30 Jul 2025 18:00 #261392
Replied by jackonlyjack on topic Gearbox fill plug and Spark plug tube oil seals
Martin Lines who run this site and bigjimny shop will be able to supply the plug seals ask him for a price
Gearbox filler people have cut an hole in the transmission tunnel so you can access the filler plug from the inside
Then made a plate to blank off the hole
I'm not sure you can fill the box another way
31 Jul 2025 15:12 #261409
by sj_4x4
Replied by sj_4x4 on topic Gearbox fill plug and Spark plug tube oil seals
Thanks, by the time I've messed about with all that's needed to neatly cut a hole in the transmission tunnel, I could have the gearbox on the floor !
I see Martin is away, I'll chase him up on his return.
