Replacement of rocker box gasket.
01 Jun 2025 09:51 #260685
by passy
Replacement of rocker box gasket. was created by passy
Is there a simple way to get the rocker box gasket to sit in position when laying the cover back on ? do you seat the gasket into the cover first or lay the gasket onto the cylinder head and try and slip it into position ?
01 Jun 2025 10:16 #260686
Replied by mlines on topic Replacement of rocker box gasket.
You dont say what model you have, however all the Jimnys I have worked on the gasket has little tags that fit into cut-outs in the metal cover. So fit them to the cover first.
01 Jun 2025 10:29 #260687
by passy
Replied by passy on topic Replacement of rocker box gasket.
Hi engine is an M13A on a 2002 jimny.
03 Jun 2025 10:30 #260715
Replied by yakuza on topic Replacement of rocker box gasket.
A slight coating of mounting grease or liquid gasket usually make the gaskets hang on the part you want them to.
Time to create page: 0.407 seconds
