Crank pulley knocking
27 May 2025 09:56 #260617 by passy
Replied by passy on topic Crank pulley knocking
I that the pulley rubber is failing and when the belt for the alternator is connected its enough to pull it out of alignment to just catch on the engine casing as it rotates. I will report back as I progress.
27 May 2025 09:58 #260618 by passy
One more question. Is the bolt on the pulley a standard "Righty tighty Lefty loosey " ?
27 May 2025 13:17 #260620 by Luke5305
Replied by Luke5305 on topic Crank pulley knocking
Normal thread. Loosen by pulling anti clockwise.
27 May 2025 14:31 - 27 May 2025 14:33 #260621 by Rogerzilla
Replied by Rogerzilla on topic Crank pulley knocking
I had mine changed towards the end of last year as a precaution, and since I was having a new radiator so it was easy to access.  The one that came off didn't look great, with a lot of long cracks in the rubber.  Idle feels smoother, but there's no difference at higher revs.
As it's an auto, the mechanic said it was easy to undo the bolt by removing a cover on the transmission and locking it there.
Last edit: 27 May 2025 14:33 by Rogerzilla.
01 Jun 2025 09:49 #260684 by passy
Crank pulley now changed, was remarkably simple once the rad and fan have been removed and just took a bit of brute force.
01 Jun 2025 10:46 #260688 by fordem
Replied by fordem on topic Crank pulley knocking
Do you still think you need to change the cylinder head or the entire engine?
Time to create page: 0.619 seconds
